Print at Sep 29, 2026, 12:54:59 PM View all posts in this thread on one page
Posted by nzr at Mar 6, 2016, 10:07:48 AM
The problem can't be solved
The design of the shopping center.
The windshield not be seen
Glass is not clear ؟؟؟ Where is the problem ؟؟؟؟؟؟؟
As well as the non-appearance of wall color (white)
I dont know how do I work the door glass ؟؟؟؟؟؟
thanks
Posted by okh at Mar 6, 2016, 11:42:59 AM
Re: The problem can't be solved
Design looks nice...
Glass is not clear ... Where is the problem....
The glass transparency depends on the model you use. Transparency could be either by a semi-transparent texture (which can be changed), or a model with transparent surface. You could try other models like some found in the Libraries of 3D models, especially the new models in 3DModels-Contributions-1.6.1.zip. - you can also find the individual window models in the Free 3D models:window - but remember to import them as Door/window.
If the transparency is not a texture, but a transparent surface in the model, it is possible to export the window to .obj and edit the transparency in the .mtl file - not entirely straightforward, but some threads (like 5056) might help you if you want to try.
As for white colour, I am not sure what you mean. But white will never render as 100% white, as that would not create a life-like rendering.
