Print at Sep 21, 2026, 8:37:39 AM
Posted by CCPT at Mar 5, 2016, 1:14:28 PM
Join (or merge) 2 adjacent walls?
Hi
When I draw 2 or more walls in a single process, adjacent walls are drawn with a "join" between them:
However if I draw the adjacent walls at different times they don't "join" together - and has a result if the 2 walls have different colors in 3d view we see a vertical stripe on the union off the 2 walls:
Is it possible to "merge" these 2 walls?
Thanks,
CC
Posted by okh at Mar 5, 2016, 4:18:00 PM
Re: Join (or merge) 2 adjacent walls?
The #4 Advanced plan editing plug-in available from the SH3D SF plug-ins allows you to connect / join two selected walls (that run in the 'same' direction, when they are selected in the correct order). ok
Posted by CCPT at Mar 5, 2016, 11:22:19 PM
applause   Re: Join (or merge) 2 adjacent walls?
Thank you - this plugin solved my issue.
