Print at Jul 12, 2026, 1:11:41 AM View all posts in this thread on one page
Posted by SNAKE83 at Mar 4, 2016, 2:49:08 PM
How to start SH3D without recovery
Hi
I have been using .jar version, once it crashed
now when I am starting, it shows in title bar [Recovered] with 100% cpu and nothing happens, just freeze.
How to force start without opening last project or automatic recovery ?
OSX 10.11.3
SH3D 5.2
console output
java -jar SweetHome3D-5.2.jar
3D [dev] 1.6.0-pre12-daily-experimental daily
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: conn 0x457b3 token 0x1ffffffffffe850
Mar 4 14:43:21 java[14685] <Warning>: Backtrace (at 130669):
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 0 CoreGraphics 0x00007fff93987ecd CGSDisableUpdateToken + 210
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 1 AppKit 0x00007fff8d631c20 ___disable_updates_sync_block_invoke_2 + 17
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 2 libdispatch.dylib 0x00007fff9201833f _dispatch_client_callout + 8
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 3 libdispatch.dylib 0x00007fff92019926 _dispatch_barrier_sync_f_invoke + 74
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 4 AppKit 0x00007fff8d630de9 NSCGSDisableUpdates + 213
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 5 AppKit 0x00007fff8d631fff NSCGSTransactionRunPreCommitActionsForOrder_ + 156
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 6 AppKit 0x00007fff8d631014 NSCGSTransactionRunPreCommitActions_ + 21
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 7 AppKit 0x00007fff8d6314ea -[_NSCGSTransaction synchronize] + 33
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 8 AppKit 0x00007fff8d631b38 NSCGSTransactionSynchronize + 76
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 9 AppKit 0x00007fff8d405e09 -[NSSurface syncSurfaceWantsExtendedDynamicRange] + 150
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 10 AppKit 0x00007fff8cd3e3d9 -[NSSurface _createSurface] + 677
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 11 AppKit 0x00007fff8cd3dd34 -[NSSurface setFrame:] + 785
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 12 AppKit 0x00007fff8d405f0f __38-[NSSurface syncToViewUnconditionally]_block_invoke + 154
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 13 AppKit 0x00007fff8d532659 NSPerformVisuallyAtomicChange + 147
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 14 AppKit 0x00007fff8cd3d658 -[NSSurface syncToViewUnconditionally] + 100
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 15 AppKit 0x00007fff8d405fa8 __37-[NSSurface orderSurface:relativeTo:]_block_invoke + 44
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 16 AppKit 0x00007fff8d532659 NSPerformVisuallyAtomicChange + 147
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 17 AppKit 0x00007fff8cd3d52d -[NSSurface orderSurface:relativeTo:] + 160
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 18 AppKit 0x00007fff8d00aece NSOpenGLContextAttachOnScreenViewSurface + 183
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 19 AppKit 0x00007fff8d34e9ea __27-[NSOpenGLContext setView:]_block_invoke + 192
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 20 AppKit 0x00007fff8d532659 NSPerformVisuallyAtomicChange + 147
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 21 AppKit 0x00007fff8cff6204 -[NSOpenGLContext setView:] + 119
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 22 extension1305372661709663617.jnilib 0x000000011e0ce790 createContext + 400
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 23 extension1305372661709663617.jnilib 0x000000011e130ea5 Java_jogamp_opengl_macosx_cgl_CGL_createContext0__JJZJZLjava_lang_Object_2I + 149
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 24 ??? 0x000000010c932758 0x0 + 4505937752
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 25 ??? 0x000000010c926175 0x0 + 4505887093
Mar 4 14:43:21 java[14685] <Warning>: void CGSUpdateManager::log() const: 26 ??? 0x000000010c926175 0x0 + 4505887093
Posted by Puybaret at Mar 5, 2016, 11:00:48 AM
Re: How to start SH3D without recovery
The files that Sweet Home 3D tries to recover at its start have a .recovered extension and are stored in the C:\Users\userrecovery subfolder that you can find in a private folder that depends on your system:
- C:\Users\user\AppData\Roaming\eTeks\Sweet Home 3D under Windows Vista / 7/8/10,
- C:\Documents and Settings\user\Application Data\eTeks\Sweet Home 3D under Windows XP and previous versions of Windows,
- Library/Application Support/eTeks/Sweet Home 3D of your user folder under Mac OS X,
- Library/Containers/com.eteks.sweethome3d.SweetHome3D/Data/Library/Application Support/eTeks/Sweet Home 3D of your user folder under Mac OS X Mac App Version,
- .eteks/sweethome3d of your user folder under Linux and other Unix,
- data of the folder that contains Sweet Home 3D applications under the portable version.
Under Mac OS X, to ensure you pick the right eTeks folder, you can open a new window in the Finder, select Go > Go To Folder menu item (cmd + Shift + G shortcut), and enter the folder ~/Library/Application Support or ~/Library/Containers/com.eteks.sweethome3d.SweetHome3D/Data/Library/Application Support/eTeks/Sweet Home 3D.
If you don't mind, please send me the .recovered file that caused your issue. When a recovered candidate file can't be opened, it's supposed to be renamed with a .unrecoverable extension to avoid the loop bug you encountered. If I can find how to detect the problem in your file, I'll fix this mechanism.
