Print at Sep 10, 2026, 6:14:28 AM View all posts in this thread on one page
Posted by enkonyito at Feb 20, 2016, 5:13:39 PM
Inability to install Sweet Home 3D 5.2 on Windows Vista
When I do right click "Run as administrator" on SweetHome3D-5.2-windows.exe, nothing happens.
So I can not use the SweetHome3D.l4j.ini file.
With SweetHome3D-5.1-windows.exe, the installation window opens.
EnkoNyito
Posted by Puybaret at Feb 20, 2016, 6:02:12 PM
Re: Inability to install Sweet Home 3D 5.2 on Windows Vista
I hope you'll find the reason why it doesn't work for you, just because I don't have any PC with Vista to test the installer. I tested it on Windows XP, 8.1 and 10.
But why do you need to run the installer with Run as administrator menu item?
Posted by enkonyito at Feb 22, 2016, 12:00:20 AM
Double-clicking does not work, I tested the right click...
I have not had any problems with the beta versions of the installer.
The SweetHome3D.l4j.ini file was useful to set preference the rendering properties. As I use the portable version instead, I should find another solution.
EnkoNyito
