Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Using light, how can I set ? |
| Print at Aug 16, 2026, 5:00:14 AM | |
| Posted by Tiso at Feb 15, 2016, 10:37:42 AM |
Using light, how can I set ? Hi there, I have tried to set a light into a room, but I dont the same atmosphere as show in some picture of the website. Is there a trick to do it? Thanks |
| Posted by hansmex at Feb 15, 2016, 12:02:15 PM |
Re: Using light, how can I set ? It's difficult to give an advice without seeing any picture(s). In general, if you want more or less realistic lighting of a room, you should: - disable Add ceiling lights in the Create photo dialogue - use large lights (e.g. 100x100x100 cm) at a low strength to give a basic light level in the room - use smaller accent lights to indicate other light sources - experiment, experiment, experiment. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Tiso at Feb 15, 2016, 3:52:15 PM |
Re: Using light, how can I set ? Thank you for your quick replay, but I don't see any "add ceiling light" in the create photo dialog box. |
| Posted by SnakeGB at Feb 15, 2016, 9:50:10 PM |
Re: Using light, how can I set ? move the quality slider to best then it will show add ceiling loght check box |
Current timezone is GMT Aug 16, 2026, 5:00:14 AM |
