Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to make a horizontal tube |
| Print at Aug 16, 2026, 11:48:35 PM | |
| Posted by Wmatilda at Feb 13, 2016, 10:39:15 PM |
How to make a horizontal tube Hi all, Please Help!! I'm desperate to know how to make a horizontal pipe/tube? Thanks in advance.. |
| Posted by okh at Feb 14, 2016, 8:01:45 PM |
Re: How to make a horizontal tube Import the cylinder from the free models page - rotate to horizontal during import (green arrows). Scale to correct size. ok |
| Posted by Wmatilda at Feb 20, 2016, 2:17:04 PM |
Re: How to make a horizontal tube Thanks for your help. How can I make this cylinder hollow? |
| Posted by okh at Feb 20, 2016, 3:53:54 PM |
Re: How to make a horizontal tube How can I make this cylinder hollow? Well, it is hollow already... but if you want to open the ends you can set top and bottom to invisible (requires newest 5.2) - but as the inside has not texture - it may not give the effect you want.Which means you are probably better off trying the cylinder shared by Ceciliabr in thread 6462 - that should be open ended. ok |
Current timezone is GMT Aug 16, 2026, 11:48:35 PM |
