Print at Sep 26, 2026, 2:11:44 PM View all posts in this thread on one page
Posted by james67210 at Feb 10, 2016, 4:23:34 PM
Visibilité du toit / hidden roof
-- FR --
Bonjour,
J'ai un problème avec le rendu d'une toiture.
En effet, il n'apparaît que sous certains angles. Impossible d'avoir le toit en entier... Quel est le problème ?
Merci
-- EN --
I have a problem with rendering the roof.
Indeed , there appears to under CERTAIN angles. Could not have the entire roof ... What's The Problem ?
Thank you
Posted by Puybaret at Feb 10, 2016, 6:57:05 PM
Re: Visibilité du toit / hidden roof
It looks like the triangles that you use are single sided and the visible side is oriented towards the ground.
When you import them, you should select the option Invert back and front faces at the second step of Furniture import wizard. You could also use some double sided triangles or simply use this simple triangle that you'll resize.
Posted by james67210 at Feb 15, 2016, 4:15:19 PM
Thanks for your reply.
I tried several times, but nothing to do, the result is not good .
At first I put rooms with just the visible top.
I'm lost.
Posted by hansmex at Feb 15, 2016, 5:35:34 PM
If you want, send me the file and I'll have a look at it.
