Print at Sep 9, 2026, 10:06:50 PM
Posts: 15   Pages: 2   [ 1 2 | Next Page ]
Posted by hansmex at Feb 10, 2016, 9:58:18 AM
Library Editor won't run under Windows 10
Is there a way to get the Library Editor to run under Windows 10?
I tried the following:
- point the jar file to the Java location in Program Files(x86) (tried java and javaw)
- uninstall and install newest Java (now 1.8.83)
- delete and download newest Library Editor (now 1.18)
- write a .bat script (java -jar FurnitureLibraryEditor-1.18.jar)
- every other tip/trick I could find
Is it possible to write a script so that the jar file starts, just like SH3D starts?
Posted by okh at Feb 10, 2016, 10:34:53 AM
Re: Library Editor won't run under Windows 10
Both Furniture and Texture Library Editors work directly under my installation of Win 10 (upgrade from 8.1).
However, Win 10 upgrade did mess with several file associations and extensions. Win10 seemingly uses additional ways if deciding how files should open. Or it could be that Edge/Internet Explorer under Win10 has added another (hidden) extension/association to the file during download.
.jar extension here is set to work with Java(TM) Platform SE binary (just like original configuration under Win 8.1).
If that does not work, you could of course try Linux smile
Posted by hansmex at Feb 10, 2016, 11:30:53 AM
Thanks, OK, will try to look for double interpretation of extensions.
I regret having allowed my friend to install Windows 10 on my PC. I was happy with Ubuntu...
Similarly, sh3f files aren't imported correctly. It opens them with SH3D, but doesn't add them to .eteks.
While hunting for a Java solution, I noticed that some files were seen as .zip files in one instance (which they technically are), but were (correctly) identified as SH3D files somewhere else.
Posted by okh at Feb 10, 2016, 12:18:44 PM
...install Windows 10 on my PC. I was happy with Ubuntu...
For very many years I always used a dual boot with both Linux and Windows - and Mac at work. Alas, I rely on some software that cannot be run under Linux, so I ended up using Win almost all the time. But now, on my Win10 computer, I will install Linux too. I need that computer from some tasks, but seem to spend more time on scratching my head over Win10 oddities (and endless upgrades). Just haven't decided on Linux-distro yet.
... sh3f files aren't imported correctly. ... .zip files in one instance (which they technically are), but were (correctly) identified as SH3D files somewhere else.
I think this is a related problem - at least this is my theory so far: When downloading with Win10, both Edge and IE (not Firefox/Opera) add a long range of extensions to the different SH3D files (looks like all extensions associated with SH3D). But only the last one is recognised. So SH3D may think it is getting one kind of file, while in reality getting another.
I have yet to explore exactly what happens, but to begin with I would not let Win Hide known file extensions and look carefully at extensions and file associations in Windows.
Posted by hansmex at Feb 10, 2016, 1:56:19 PM
In Windows 10, I went to Configuration -> Programs -> Default -> Establish default links (or something similar, I translated from a Dutch Windows version).
I checked that:
- *.jar points to Java SE
This was the case, nevertheless I renewed this default
- *sh3* point to SH3D
It turns out *.sh3t does NOT point to SH3D (the others do). This may explain some of the problems people have when adding texture libraries.
I cannot find other places where I can set these defaults.
I restarted my PC. JAR files still don't start. After double-clicking the jar-file, a window pops up briefly, then disappears. That's all.
Posted by Puybaret at Feb 10, 2016, 2:39:03 PM
Hans, please try to run the Editor from the command line:
- run cmd
- type java -jar and drag and drop FurnitureLibraryEditor-1.18.jar file in the command window to get its path
- type <Enter>.
If there's a problem, there should be some log that appears in the command window. Please report it here, so I can help you further.
Posted by okh at Feb 10, 2016, 3:00:42 PM
This may not solve your specific issue, but just in case, I would still make sure you do not hide known extensions. To give you an example:
If you download userGuideExample.sh3d both IE and Edge (under Win10) will name the file:
userGuideExample[1].sh3d .sh3l .sh3f .sh3t .sh3p
when downloading. Win8.1 keeps the original file name and does not create this mess.
Under Win10 SH3D opens the file, not as a plan (.sh3d) but as a plugin (.sh3p). SH3D puts the file in the plugin directory, reports successful plugin installation (SH3D does not open the plan or show the file in the plugin list - of course, it is not a plugin - the file just fills up ...\Application Data\eTeks\Sweet Home 3D\plugins with no meaning in life).
This gets even more confusing if known extensions are hidden (see Control Panel / Appearance and personalisation / File Explorer Options / View / Hide extensions for known file types). With hidden option on, the LAST of those extensions are concealed from the user. The actual .sh3d file, looks like a .sh3t file (userGuideExample[1].sh3d .sh3l .sh3f .sh3t) and is treated like a .sh3p file.
I did see something about how Win10 has improved features in terms of sniffing out correct file types. I stopped reading, decided to go back to dual boot for my play PC, and not letting Win10 anywhere near a computer used for actual work.
Posted by hansmex at Feb 10, 2016, 3:37:22 PM
C:\Users\Hans>java -jar C:\Users\Hans\Downloads\FurnitureLibraryEditor-1.18.jar
feb 10, 2016 3:22:42 PM java.util.prefs.WindowsPreferences <init>
WARNING: Could not open/create prefs root node Software\JavaSoft\Prefs at root 0x80000002. Windows RegCreateKeyEx(...) returned error code 5.
@Emmanuel,
Above what happens when I do as you told.
Result: Library Editor starts correctly. THANK YOU !!!
I have changed my *.bat script so that it includes the path to the file.
Result: DOS window opens with same error message as above; Library Editor starts correctly.
EDIT
Indeed, I can import files in the Library Editor.
Problem: ALL imported .zip files are called "Model", even when all file names are different. (= Scopia/Hausmann windows from 3D models page.)
END EDIT
@OK
1
- Extensions are visible for all files. I changed this a few weeks ago, and I re-checked today that I did it the correct way.
2
- If I download your example file, it is shown with the extension .sh3d.
- If I double-click the file, SH3D opens and shows the design.
- improved features? Only improved features in W10 are high blood pressure and bugs.
Posted by Wendell_Burke at Nov 29, 2024, 5:28:19 AM
Het there,
I'm also having trouble getting the Library and Texture editors to work on my Windows system and was hoping I could get some help with it on here? I’m running Windows 10 Pro, I’ve installed the Java Development Kit 23.0.1 (64 bit), but that just seems to be a collection of weblinks. I installed Java Version 8 Update 431, (Build 1.8.0_431-b10), and I’ve downloaded Furniture Library Editor 2.2, but when I double click on it, nothing happens. I tried the advice Puybaret offered, but for me, I got...
"Unrecognized option; -jarC: \Users/ (My login)\ Downloads\FurnitureLibraryEditor-2.2 (4).jar
Error: Could not create the Java Virtual Machine.
Error: A fatal exception has occurred. Program will exit."
I need to get the furniture editor up and running as I’m working on a project with custom lights. I’m also totally new to 3D modelling, but I’ve been teaching myself what I can so far, and others here have been helpful in offering explanations as well. Can anyone please help me out with this?
Posted by Wendell_Burke at Nov 30, 2024, 3:42:58 AM
I'm having the same problem. I entered
java -jar"C:\Users\(My login)\Downloads\FurnitureLibraryEditor-2.2 (4).jar" Enter
And got...
Unrecognized option: -jarC:\Users\(My login)\Downloads\FurnitureLibraryEditor-2.2 (4).jar
Any help would be appreciated!
