Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Progress and time of photo rendering |
| Print at Aug 16, 2026, 7:00:58 PM |
| Posted by alaX at Jun 24, 2016, 4:30:16 PM |
Re: Progress and time of photo rendering (Create photo with renderer plug-in) enkonyito, Your plug-in is great but I encountered some issues. 1) When "Apply proportions" is set to "3d view", changing image width to any value always makes height = 2,147,483,647; new height value makes width = 0. Switching back from "Square", "4/3" and other proportions presets (that work fine) also causes this unwanted effect. If I want my image to keep proportions of 3d view but I need to change size I have to do it via standard "Create photo" window. 2) "Create photo with renderer" window doesn't fit to my screen height(1024x600px) - I don't see "Create", "Save" and "Close" buttons, even if I move or hide task bar. I use Tab key but I have to carefully count hits to avoid accidental skipping "Save" button when I'm finally satisfied with my image. screenshot I would be grateful for fixing it. |
| Posted by enkonyito at Jun 26, 2016, 1:42:53 AM |
Re: Progress and time of photo rendering (Create photo with renderer plug-in) alax, 1) When "Apply proportions" is set to "3d view", changing image width to any value always makes height = 2,147,483,647; new height value makes width = 0. I can not reproduce it even by displaying the 3D view in a separate window. Is this occasional or systematic? Have others met the same kind of problem? 2) "Create photo with renderer" window doesn't fit to my screen height(1024x600px) - I don't see "Create", "Save" and "Close" buttons, even if I move or hide task bar. This will be fixed in the next version of the plugin that will be soon available. ---------------------------------------- EnkoNyito |
| Posted by alaX at Jun 26, 2016, 8:07:14 PM |
Re: Progress and time of photo rendering (Create photo with renderer plug-in) Thanks for reply. I can not reproduce it even by displaying the 3D view in a separate window. Is this occasional or systematic? - With 3D view docked (in main window) everything works fine. - When I open "CPwR" first and then detach 3D view - it also works fine. - Problem occurs every time I open "CPwR" when 3D view window is already floating(in my case - almost all the time). What I forgot to mention in my previous post - resizing this floating 3D view window manually(dragging edges) makes no changes to width and height fields in "CPwR". Have others met the same kind of problem? Apparently, only me and I have met this problem - it happens on my both laptops - WinXP and Win7(32-bit).This will be fixed in the next version of the plugin that will be soon available. ![]() |
| Posted by enkonyito at Jun 28, 2016, 2:29:24 AM |
Re: Progress and time of photo rendering (Create photo with renderer plug-in) - Problem occurs every time I open "CPwR" when 3D view window is already floating(in my case - almost all the time). What I forgot to mention in my previous post - resizing this floating 3D view window manually(dragging edges) makes no changes to width and height fields in "CPwR". By following your procedure, I was able to test the bug and find a solution. ![]() ---------------------------------------- EnkoNyito |
| Posted by alaX at Jun 29, 2016, 1:47:28 AM |
Re: Progress and time of photo rendering (Create photo with renderer plug-in) That's great! You're the man! ![]() |
| Posted by enkonyito at Jul 2, 2016, 10:58:04 PM |
Re: Progress and time of photo rendering (Create photo with renderer plug-in) Version 1.3 - Added advanced settings for rendering properties - Enhancement option to external brightness (sky with or without texture) - Fixed a 3D view management bug in a separate window - Fixed a photo panel resizing bug for small screens - Other minor fixes and improvements ---------------------------------------- EnkoNyito |
| Posted by enkonyito at Jul 13, 2016, 6:42:16 PM |
Re: Progress and time of photo rendering (Create photo with renderer plug-in) In case of problems with previous links (unavailability of sourceforge), use the one attached. ---------------------------------------- ---------------------------------------- EnkoNyito |
| Posted by danger89 at Sep 2, 2016, 1:33:53 AM |
Re: Progress and time of photo rendering (Create photo with renderer plug-in) I had a lot of issues with the default render engine, especially the quality of the image (yes I disable ceiling lights and add lights myself) .. I got strange art-effects, white spots, dark spots -> know issues, never get fixed. I really couldn't found any solution. Exporting & importing to Blender is an alternative way, but way to complicated for now. . Until I found this plugin. Although I have still strange white spots with this plugin :(. It could because of my chandelier (lot of glass)... |
| Posted by danger89 at Sep 2, 2016, 1:40:57 AM |
Re: Progress and time of photo rendering (Create photo with renderer plug-in)In case of problems with previous links (unavailability of sourceforge), use the one attached. Maybe I'm too harsh, I really like that you put effort into the rendering engine. Kudos for that! Don't get me wrong. But the future could be to switch to a better engine? Like from Blender perhaps.I really like Sweet Home 3D actually, but the render engine should get replaced by a more modern engine using GPU. |
| Posted by enkonyito at Sep 3, 2016, 7:33:26 PM |
Re: Progress and time of photo rendering (Create photo with renderer plug-in) Although I have still strange white spots with this plugin... This plug-in also uses the default rendering engine.But the future could be to switch to a better engine? Like from Blender perhaps. Change rendering engine means respecting certain conditions for open source software like Sweet Home 3D.---------------------------------------- EnkoNyito |
Current timezone is GMT Aug 16, 2026, 7:00:58 PM |
