Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: loadlibrary failed with error 1114 a dynamic link library |
| Print at Jun 19, 2026, 3:58:01 PM | |
| Posted by AhmadSaied at Jan 23, 2016, 9:41:56 PM |
loadlibrary failed with error 1114 a dynamic link library I have this problem, and I could not fix it my windows is win 10 ,laptop is HP pro book |
| Posted by diegokeller at Feb 18, 2016, 11:37:43 AM |
Re: loadlibrary failed with error 1114 a dynamic link library I had the same problem. Windows 10. Java 8. I solve the problem doing this: -Install Java 7. -Download Sweet Home 3D in the JAR version. -Create a .BAT file that calls the JAR, something like this: "C:\Program Files\Java\jdk1.7.0_79\bin\java.exe" -jar sweet-home-3d.jar |
| Posted by Puybaret at Feb 18, 2016, 3:24:50 PM |
Re: loadlibrary failed with error 1114 a dynamic link library Could you try if version 5.2 fixed this issue? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by diegokeller at Feb 19, 2016, 1:18:04 PM |
Re: loadlibrary failed with error 1114 a dynamic link library In my case, I tried version 5.2, using the windows installer, but with no success. The only thing that worked was as I described in my previous post. |
| Posted by Puybaret at Feb 19, 2016, 8:49:45 PM |
Re: loadlibrary failed with error 1114 a dynamic link library Too bad ![]() There must a conflict somewhere with Windows 10. At least, it's good to know that it works with Java 7. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Puybaret at Mar 9, 2016, 4:52:13 PM |
Re: loadlibrary failed with error 1114 a dynamic link library Please see if the solution shown in this video will help. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by lausteph at May 18, 2016, 6:12:08 PM |
Re: loadlibrary failed with error 1114 a dynamic link library Hi all, it works on win 10 when you maximize performance of the switchable dynamic graphics (as explaned in the video). |
| Posted by AhmadSaied at May 18, 2016, 11:40:58 PM |
Re: loadlibrary failed with error 1114 a dynamic link library it works on win 10 when you maximize performance of the switchable dynamic graphics (as explaned in the video). Yes it works but I can not shut down my laptop , I had to push the button to close And when you open your laptop again do not enter windows so I did re instal win 10 because I don't know how to open in in save mod to cancel every thing there |
| Posted by nicolaslll at Apr 8, 2020, 5:09:05 PM |
Re: loadlibrary failed with error 1114 a dynamic link library comon it s 2020... |
Current timezone is GMT Jun 19, 2026, 3:58:01 PM |
