Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Can't update level 0 after adding Level1 |
| Print at Sep 20, 2026, 6:42:40 AM | View all posts in this thread on one page |
| Posted by ppmt at Jan 13, 2016, 11:06:36 PM |
Can't update level 0 after adding Level1 Hello, By following several tutorial I have managed to create the ground floor of my house and was very happy with it. Now I am on to design the first floor. Now that I have done that I foind out that I can no longer edit the ground floor. If I click on the level0 tab I can't select anything. I can add to it but everything that was created before adding the second level is no longer accessible. Am I missing something? |
| Posted by santbose at Jan 15, 2016, 7:56:00 AM |
Re: Can't update level 0 after adding Level1 Can you please send the SH3D file so that I can have a look at it |
| Posted by hansmex at Jan 15, 2016, 9:01:44 AM |
Re: Can't update level 0 after adding Level1 Check that you didn't accidentally activate Lock base plan. ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by ppmt at Jan 15, 2016, 4:17:24 PM |
Re: Can't update level 0 after adding Level1 @hansmex : I have checked and it is not. @santbose: I have sent you a private email with my file. Sorry for the size. I had not realised it could be so big until after I sent it |
| Posted by Puybaret at Jan 20, 2016, 10:03:55 AM |
Re: Can't update level 0 after adding Level1 santbose, did you succeed to fix ppmt's issue? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by ppmt at Jan 27, 2016, 10:46:12 PM |
Re: Can't update level 0 after adding Level1 If I get some time I will start from scratch to see if the same happens again. |
Current timezone is GMT Sep 20, 2026, 6:42:40 AM |
