Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Version 5.1 doesn't work in windows10, but version 5.0 does |
| Print at Jul 21, 2026, 9:04:45 PM | |
| Posted by rickspain at Jan 7, 2016, 6:29:27 PM |
Version 5.1 doesn't work in windows10, but version 5.0 doesI upgraded to version 5.1 from version 4.4 under windows10 and message displayed said my graphics drivers need updating. Tried updating and message said present versions up to date. Now what? Reverted back to version 5.0 after much searching and that works fine. What happened in the update - is there a fix? |
| Posted by Puybaret at Jan 11, 2016, 3:49:49 PM |
Re: Version 5.1 doesn't work in windows10, but version 5.0 does Please try the version 5.2 Beta 1 and report us how it works. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by sushmitha at Jan 14, 2016, 11:17:24 AM |
Re: Version 5.1 doesn't work in windows10, but version 5.0 doesReply for version 5.1 doesn't work in windows 10 |
| Posted by eldurotuti at Jan 25, 2016, 3:49:49 PM |
Re: Version 5.1 doesn't work in windows10, but version 5.0 doesiT'S WORK in windows 10. |
| Posted by HawkDawg at Jan 26, 2016, 8:20:03 AM |
Re: Version 5.1 doesn't work in windows10, but version 5.0 does iT'S WORK in windows 10. Which one are you referring to? ---------------------------------------- Hawk |
| Posted by sushmitha at Jan 28, 2016, 5:59:25 AM |
Re: Version 5.1 doesn't work in windows10, but version 5.0 does yes it work in windows 10 |
| Posted by Puybaret at Jan 28, 2016, 9:22:45 AM |
Re: Version 5.1 doesn't work in windows10, but version 5.0 does sushmitha, what did you change to make it work under Windows 10 in your case? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by eldurotuti at Jan 28, 2016, 3:21:13 PM |
Re: Version 5.1 doesn't work in windows10, but version 5.0 does Which one are you referring to? The beta 5.2 work for me. |
| Posted by flyboy60 at Feb 1, 2016, 3:24:21 PM |
Re: Version 5.1 doesn't work in windows10, but version 5.0 does Neither version will install. I receive a message that the signature of this program is corrupt or invalid |
| Posted by Puybaret at Feb 1, 2016, 7:17:21 PM |
Re: Version 5.1 doesn't work in windows10, but version 5.0 does The signature is not corrupted. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Puybaret at Feb 2, 2016, 6:16:19 PM |
Re: Version 5.1 doesn't work in windows10, but version 5.0 does After a request to the company that issued the certificate used to signed Sweet Home 3D, it seems the problem could be bound to the fact that this certificate uses SHA-1 and not SHA-2. As said previously, this doesn't make the program corrupted though. I'm going to request a SHA-2 certificate that I'll use to sign the next version. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by stefbu at Feb 3, 2016, 5:43:14 PM |
Re:
Version 5.1 doesn't work in windows10, but version 5.0 does same problem even with version 5.2. Work only version 5 |
| Posted by Puybaret at Aug 4, 2017, 11:44:50 PM |
Re: Version 5.1 doesn't work in windows10, but version 5.0 does To those of you who had some problems with versions 5.1 or 5.2 last year, could you test again whether Sweet Home 3D 5.2 still crashes, then try the behavior of the version 5.5 beta 11. If the Beta version doesn't crash anymore, that will mean that the issue in Java 8 will have been fixed. Thanks for your help and feedback! ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Jul 21, 2026, 9:04:45 PM |
