Print at Sep 10, 2026, 8:51:26 AM View all posts in this thread on one page
Posted by Strikkie at Dec 7, 2015, 9:51:06 PM
Cut outs of the floor
I'm building a 3 floor building in sh3d and in the middle of the rooms I want to cut out a part of the floor so that you can look from the top floor all way down to the groundfloor.
Is there an easy way to do this as I only found a PDF but this I did not understood. http://www.sweethome3d.com/SVGPathMiniManualForSweetHome3D.pdf
I hope that there is somebody out there who can help me.
thanks on forehand
Posted by okh at Dec 8, 2015, 10:40:47 AM
Re: Cut outs of the floor
Sorry about the SVG manual, but there is no need to do anything that drastic just for an opening.
..cut out a part of the floor so that you can look from the top floor ...
Two simpler options spring to mind:
1) Draw the floor manually with the floor drawing tool, leaving a hole/cut-out where you want it.
2) Import one (or more) boxes as staircases. The boxes should be invisible, which you can get by using an invisible texture (like invisible.png). If you size and lift the box(es) to the ceiling below, they can cut out the hole you need. The boxes are possibly faster to change later, but may be in the way when you work on the ground floor (in which case you can make an intermediate level just under the ceiling just for the cut-out boxes).
Hope this helps. ok
