Print at Sep 19, 2026, 10:28:19 PM
Posts: 11   Pages: 2   [ Previous Page | 1 2 ]
Posted by okh at Dec 11, 2015, 9:12:07 AM
Re: Recent experiment
PCjr.
.. orthorectangular projection issues ...
Yes, true it is hard to make it look good (see thread 5533 for sky projection). Simply put, the horizon needed a lot of sky above and only a thin stretch of ground view, and still only good on some locations (with a wide view).
..it belongs more in the midground... ..something to do with relative elevation...
Yes but just a little elevation, like lifting the plan a couple of metres up with terrain under, changes the perspective considerably. Still, sky texture should represent a view near the actual horizon. For closer items, the workaround is better. The biggest problem, I find, is that big exterior objects shifts the view angle in aerial view further back (even if that level is hidden), hence the use of a separate file. Then again, this is not the main purpose of SH3D - but still fun to play with to visualize a project. ok
