Print at Sep 24, 2026, 8:54:11 AM
Posted by makeurmark at Nov 25, 2015, 7:42:21 PM
Directory location of library?
I am running Sweet Home 3D on a mac - Yosemite.
I can't find the furniture or texture library.
I have followed the directory paths advise and I've searched for key words, but nothing.
I even tried searching for eteks as I am lead to believe that the library sits inside this folder.
I also tried showing hidden directories.
Any advise would be gratefully received.
Thanks
Posted by Puybaret at Nov 26, 2015, 12:11:29 AM
Re: Directory location of library?
You should open the About dialog box, then click on the Libraries... button it contains. This will display a Libraries in use panel where each listed library is actually an hyperlink on which you can click to show it in the Mac OS X Finder, Windows Explorer or Linux file browser.
Posted by makeurmark at Nov 26, 2015, 12:42:12 AM
Thanks Puybaret. I'd never have worked that out for myself.
Is there any ay of viewing each item rather than the library files?
Are there any resources on building your own furniature?
Thanks again
Posted by techdoctor at Apr 2, 2019, 6:12:43 PM
Just tried this and The libraries button only shows Textures and plugins. No furniture. So where is the furniture library stored on a Windows 10 machine
Posted by Mike53 at Apr 6, 2019, 11:18:39 PM
Something like this should get you there:-
C:\username\AppData\Roaming\eTeks\Sweet Home 3D\furniture
Posted by coccobrillo at May 20, 2019, 8:57:27 AM
@Mike53
I have checked right now in my system
it is not such tricky :-)
it is just in
\Users\username\eTeks\Sweet Home 3D
I suppose it is the same in Mac OS
Posted by dorin at May 20, 2019, 8:20:41 PM
1. This program came with their default feature which are in their installation path; could be modified but is not so simple.
2. About dialog will show ONLY the imported plugins, furniture library and/or texture.
@techdoctor
If You see SOME texture and plugins in About dialog but no furniture library that's mean You've not import them; there is a lot on this site or on SourceForge.
@makeurmark
Of course it is but need some patience and work.
P.S.
I've spend 10 years with this great program and I don't discover (yet) all the features already provided by master Emmanuel and the community.
This forum is a real treasure for those who want to learn and use this program.
Anyway, keep asking. Someday You will be the one who offer answers to other new users.
Posted by UbuntuBirdy at May 20, 2019, 9:43:22 PM
AMEN! This is how every community should work, but I've never seen an other one which works as great as this one - sometimes I feel like in a big family...
Dorins last phrase should be the credo of every forum - so everyone please write it deep in your hearts and live for it - also in real life!
Pascal
Posted by socrate_54 at Jun 9, 2019, 5:15:15 PM
Hello,
I want to create a new Library for instance Tree.
I Don't want to use miscellaneous.
Do someone can help me?
Alain
Posted by dorin at Jun 9, 2019, 7:27:05 PM
1. You could download this library;
2. Import it in FurnitureLibraryEditor;
3. Change the category from "Exterior" to "Trees", save and install.
4. If You want You could add Your own trees before saving.
Posted by otadmin at Jun 28, 2020, 9:00:03 AM
Just installed the version 6.3 on Linux Mint 19.3. Read through this thread but
-my "About dialog box, then click on the Libraries... button" does not show a "Libraries" button.
-opened the texture editor, it shows no library. Not in .eteks , not anywhere. But opening the main program it uses some obviously inbuild textures. Where are they? How can I show them in the texture editor?
