Print at Jul 20, 2026, 7:32:48 PM
Posted by enkonyito at Nov 17, 2015, 5:50:21 PM
Comparative global illumination
By default, Sweet Home 3D uses global illumination "ambient occlusion".
Indirect light reflected by objects can be simulated by setting global illumination to "path".
The rendering will be longer.
EnkoNyito
Posted by HawkDawg at Nov 17, 2015, 8:10:20 PM
Re: Comparative global illumination
Where do you change this setting?
Hawk
Posted by enkonyito at Nov 18, 2015, 1:02:10 AM
By using this plug-in .
More info about it here .
EnkoNyito
Posted by HawkDawg at Nov 18, 2015, 2:34:18 AM
Thanks. I have that plugin installed. I know what you're talking about now.
Must have been a senior moment that it didn't dawn on me. laughing
Hawk
Posted by hansmex at Nov 18, 2015, 4:34:01 AM
Recently, I upgraded my PC, so it's much faster now. Therefore I decided to play around with this photo plug-in. Unfortunately, I can't figure out how it works.
Am I correct in thinking that this plug-in has effect only when making a render in Q4?
Posted by HawkDawg at Nov 18, 2015, 4:40:16 AM
I believe it works in Q3 and Q4.
Hawk
Posted by enkonyito at Nov 18, 2015, 8:18:57 PM
Hans, Hawk,
Version 1.2 of the plug-in incorporates some additional information like an illustration quality levels and a small parameters definition.
Hans:
Hawk:
It is used as a SweetHome3D.l4j.ini file, a Linux launch script or Jar command lines to change the photo renderer properties at the two best quality levels (Low/Q3 and High/Q4).
Hans:
I should perhaps make a tutorial like plug-ins and extensions User Guide .
Regarding global illumination "path" , a sky with texture can give a rendering dark, powerful lights can give a dazzling rendering.
Enko
EnkoNyito
Posted by HawkDawg at Nov 19, 2015, 7:59:32 AM
That's the one I have. smile
Hawk
Posted by enkonyito at Jan 15, 2016, 4:47:37 AM
A tutorial explaining the use of the plug-in is available here .
EnkoNyito
Posted by santbose at Jan 15, 2016, 6:11:32 AM
Hi Enkonyito,
I have downloaded the plugin 1.3 and using the portable version of SH3D 5.1. But am not able to select the filters and Sampler Algorithm. Neither the option Create photo with advanced render properties is working. Can you please help me and guide me how to use the plugin. I am doing a large scale project for my client.
Posted by santbose at Jan 15, 2016, 6:13:25 AM
I am using a Windows 7 OS
Posted by Puybaret at Jan 15, 2016, 9:02:48 AM
The two last properties can be set only in the coming version 5.2 (and not in Java Web Start version).
Posted by digitaltrails at Jan 15, 2016, 9:38:27 AM
Thanks for writing up the tutorial.
I'm just starting to play with the plugin. Here is some feedback on the tutorial.
Because experimenting with different renderings is so slow, it would be helpful if the tutorial included some examples of good values from which to start as well as some indication or reasonable ranges to try.
It would also be good to describe some different specific example values with some explanation of the visual changes one might expect as well as some measure of the impact on rendering times (doubles, triples, ..). For example, does each increment of diffused-bounces increases rendering time linearly or exponentially? What is a good practical value for diffused-bounces, one that gives reasonable results for reasonable rendering times?
I'm currently trying 1 diffused bounce, which is taking quite along time for a 256x198 image (perhaps half an hour so far - it's taking so long I lost track). I can see that I will have to experiment with image sizes of less than 256x198 in future (AMD Phenom(tm) II X6 1090T - 6 CPU cores).
Posted by enkonyito at Jan 15, 2016, 10:00:18 PM
santbose,
For the portable version of Sweet Home 3D, place the SH3P file in the data/plugins folder.
You can test the 2 new rendering properties with the beta version of the Windows installer pending the official release of SH3D-5.2 .
EnkoNyito
Posted by enkonyito at Jan 16, 2016, 3:25:22 AM
digitaltrails,
The tutorial will not only describes the use of plug-in, it can be seen as a quick start guide for this one. This is why I generally indicates the influence of some parameters on the rendering time.
In this thread , it is specified how the complexity of a project (number and power of lights; transparency, relection, refraction or brightness of objects) increases the rendering time. The number of pixels of the image and the maximum value for antialiasing also have an influence.
Regarding the path tracing, here are some examples of tests that I had done. (full size)
antiliasing max = 0, difused bounces = 1, rendering time : 03mn 57,21s
antiliasing max = 1, difused bounces = 1, rendering time : 13mn 31,50s
With additional lights little powerful.
antiliasing max = 0, difused bounces = 1, rendering time : 07mn 25,41s
antiliasing max = 1, difused bounces = 1, rendering time : 24mn 32,43s
You can choose difused bounces = 2 to enhance the brightness of a room while keeping the same antialiasing max.
Generally, I use antiliasing max = 0, diffused bounces = 0 and an image of size 2 times wider than I resizes to reduce noise (white dots).
EnkoNyito
Posted by digitaltrails at Jan 17, 2016, 9:00:55 AM
enkonyito:
Thanks for the additional examples, much appreciated.
Posted by enkonyito at Aug 29, 2017, 1:51:37 AM
At quality level 3 and 4, 3 rendering types are possible by modifying the properties.
Common settings: default values (quality 4)
Dimensions: 640x480 pixels
Default rendering
GlobalIllumination: default, diffusedBounces: 1
Contrasting rendering
GlobalIllumination: default or path, diffusedBounces: 0
Indirect rendering
GlobalIllumination: path, diffusedBounces: 1
EnkoNyito
Posted by enkonyito at Jul 12, 2019, 8:32:15 PM
The following Global Illuminations will be offered with the new version of the photo-video plug-in.
Fake Ambient Term 2 is not available with the standard version of Sweet Home 3D.
Enko
Attachment Cornell Box.sh3d (709349 bytes) (Download count: 813)
EnkoNyito
Posted by Mike53 at Jul 13, 2019, 12:06:07 AM
I like the path tracing, i do however find the jump from 16 sec to over 4 mins daunting, roughly 17 times longer, mmmmm.
Quality certainly comes at a cost
Posted by maureenowaters at Oct 12, 2019, 5:43:34 PM
Nice comparison.
Posted by enkonyito at Mar 13, 2020, 4:33:20 PM
Lighting methods of the YafaRay rendering engine.
EnkoNyito
Posted by bdfd at Mar 14, 2020, 5:49:12 AM
Without hesitation, this is the best !
wink
Posted by UbuntuBirdy at Mar 14, 2020, 11:54:28 AM
wink
Jep, I totally agree!
Pascal
Posted by Ceciliabr at Mar 17, 2020, 1:27:49 AM
Well, that may be so when it comes to rendering a test-file, but when it comes to rendering an actual project file, the outcome might not be so obvious:
Path tracing:
Direct lighting:
Test files are just test files, and will never be anything but test files, and test files do not represent anything other than themselves.
And what they represent is certainly miles apart from any project file that the average SH3D-user will ever create.
So, is the path-tracing really better than direct lighting?
Do your own tests, on your own projects, and find out.
Posted by bdfd at Mar 17, 2020, 6:36:38 AM
OMG, cec is in the thruth,.
Conclusion: each project is a particularity and the used methodology is not written in the stone.
wink
Posted by bam0o at Apr 12, 2020, 2:06:05 PM
Have the same issues with path... Tried with PVR 1.9 YafaRay renderer.
Here is little preview of the result. Don't want to waste the time to render bigger resolution.
Posted by bam0o at Apr 13, 2020, 12:04:05 AM
