Print at Jul 21, 2026, 7:47:27 AM
Posts: 27   Pages: 3   [ 1 2 3 | Next Page ]
Posted by enkonyito at Nov 17, 2015, 5:50:21 PM
Comparative global illumination
By default, Sweet Home 3D uses global illumination "ambient occlusion".
Indirect light reflected by objects can be simulated by setting global illumination to "path".
The rendering will be longer.
EnkoNyito
Posted by HawkDawg at Nov 17, 2015, 8:10:20 PM
Re: Comparative global illumination
Where do you change this setting?
Hawk
Posted by enkonyito at Nov 18, 2015, 1:02:10 AM
By using this plug-in .
More info about it here .
EnkoNyito
Posted by HawkDawg at Nov 18, 2015, 2:34:18 AM
Thanks. I have that plugin installed. I know what you're talking about now.
Must have been a senior moment that it didn't dawn on me. laughing
Hawk
Posted by hansmex at Nov 18, 2015, 4:34:01 AM
Recently, I upgraded my PC, so it's much faster now. Therefore I decided to play around with this photo plug-in. Unfortunately, I can't figure out how it works.
Am I correct in thinking that this plug-in has effect only when making a render in Q4?
Posted by HawkDawg at Nov 18, 2015, 4:40:16 AM
I believe it works in Q3 and Q4.
Hawk
Posted by enkonyito at Nov 18, 2015, 8:18:57 PM
Hans, Hawk,
Version 1.2 of the plug-in incorporates some additional information like an illustration quality levels and a small parameters definition.
Hans:
Hawk:
It is used as a SweetHome3D.l4j.ini file, a Linux launch script or Jar command lines to change the photo renderer properties at the two best quality levels (Low/Q3 and High/Q4).
Hans:
I should perhaps make a tutorial like plug-ins and extensions User Guide .
Regarding global illumination "path" , a sky with texture can give a rendering dark, powerful lights can give a dazzling rendering.
Enko
EnkoNyito
Posted by HawkDawg at Nov 19, 2015, 7:59:32 AM
That's the one I have. smile
Hawk
Posted by enkonyito at Jan 15, 2016, 4:47:37 AM
A tutorial explaining the use of the plug-in is available here .
EnkoNyito
Posted by santbose at Jan 15, 2016, 6:11:32 AM
Hi Enkonyito,
I have downloaded the plugin 1.3 and using the portable version of SH3D 5.1. But am not able to select the filters and Sampler Algorithm. Neither the option Create photo with advanced render properties is working. Can you please help me and guide me how to use the plugin. I am doing a large scale project for my client.
