Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Scale |
| Print at Sep 28, 2026, 12:49:34 AM | |
| Posted by labarnes01 at Nov 11, 2015, 3:36:36 PM |
Scale I just downloaded Sweet Home last night. I am not using it for home design at the present. What I am trying to do is draw infill walls in an attic space, exterior stairways and other misc. details. Before drawing I would like to set my scale for 3/4" to the foot. How do I do this? |
| Posted by okh at Nov 12, 2015, 9:10:25 PM |
Re: Scale Scale on screen adjusts to your plan. Zoom in/out with magnifying glasses in toolbar or Ctrl+Mouse wheel. Print scale is set in File-Page setup. ok |
| Posted by labarnes01 at Nov 15, 2015, 2:00:16 AM |
Re: Scale That isn't a lot of help when I want to create a new drawing! If you can't set a scale before starting a drawing what use is it in the field? |
| Posted by hansmex at Nov 15, 2015, 7:16:01 AM |
Re: Scale 1 - Go to File -> Preferences, select the measurement system you want. 2 - Make your drawing. A line 1 unit long, now has a length of 1 millimeter/centimeter/inch/foot. When using feet/inches, make sure to type ' or ". 3 - Go to File -> Page setup and set the scale to 1:16. If you now print your drawing, the measurements on the print should be 3/4 inch to 12 inch. (12 / 0.75 = 16) ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Puybaret at Nov 15, 2015, 4:33:51 PM |
Re: Scale Larry, when you draw a wall or the side of a room the program will indicate you the length of what you draw. The default scale at screen is 2 cm per pixel, but as you don't know the size of a pixel, this won't help. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 28, 2026, 12:49:34 AM |
