Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Print only a single room on a floor |
| Print at Sep 28, 2026, 5:31:19 AM | |
| Posted by bAdLucK at Nov 3, 2015, 10:23:07 PM |
Print only a single room on a floor Hi everybody, is there an easy solution (meaning not deleting all other rooms) to print only a single room? I have drawn the whole 1st floor of a house but in order to discuss things with the bath-guys, i would love to print only the bathroom. So far i always do a printscreen and copy paste it into paint and print it from there, which is obviously not the greatest solution imaginable. :D I didnt find any options in the SH3d itself and also couldnt find anything in this forum via the search option (maybe wrong keywords?). Thanks for your help! (I hope i'm in the right Subforum) |
| Posted by HawkDawg at Nov 3, 2015, 11:24:20 PM |
Re: Print only a single room on a floor You could select everything in the bathroom using the shift key after selecting the first object to select more objects. Once you have everything selected, right click and select Copy. Then open a new home and right click and select paste. It can be a little tricky doing this if you have something on top of something else. You can also drag a box around the bathroom to select all. You could also delete everything but the bathroom and make sure you save it as a new file so you don't lose everything. ---------------------------------------- Hawk |
| Posted by Puybaret at Nov 4, 2015, 9:18:02 AM |
Re: Print only a single room on a floor Instead of a print screen, you could also select what you want to show, copy it and paste it in a drawing tool or even a word processing software (this might not work under Linux). You could also separate this room in a first level at the same elevation, so when you select that level, only that room would be shown (see attached example). ---------------------------------------- ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 28, 2026, 5:31:19 AM |
