Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Keys.p12 certificate error.. |
| Print at Sep 13, 2026, 7:07:53 PM | |
| Posted by santhosh.chellamani at Oct 21, 2015, 4:24:07 PM |
Keys.p12 certificate error.. hi, i am getting error while trying to run ant 'applet' on my command line. error related to the certificate generated. command used to generate : keytool -genkey -keystore keys.keytool -alias SweetHome3D and certificate generation i have renamed the file as keys.p12 kindly help. Regards, santhosh |
| Posted by santhosh.chellamani at Oct 21, 2015, 4:25:25 PM |
Re: Keys.p12 certificate error.. this is the final error. [signjar] jarsigner error: java.lang.RuntimeException: keystore load: DerInputStream.getLength(): lengthTag=109, too big. BUILD FAILED |
| Posted by Puybaret at Oct 21, 2015, 9:10:59 PM |
Re: Keys.p12 certificate error.. The command used to generate the keys.p12 file is incorrect. As explained in the README.TXT file, it should be: keytool -genkey -keystore keys.p12 -alias SweetHome3D -storetype pkcs12---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by santhosh.chellamani at Oct 26, 2015, 6:54:17 AM |
Re: Keys.p12 certificate error.. Hi, Thank you so much for the support, i was successful in deploying SH3D on my server. I am able to open the applet on my server, but i am not able to import libraries. Can you please help me in guiding how to include libraries to my online version. Thanks and Regards, Santhosh C |
| Posted by Puybaret at Oct 26, 2015, 11:36:59 PM |
Re: Keys.p12 certificate error.. See this subject. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 13, 2026, 7:07:53 PM |
