Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: cut the floor for the render |
| Print at Sep 6, 2026, 7:58:26 AM | |
| Posted by lilalur at Oct 13, 2015, 3:42:34 PM |
cut the floor for the renderI modeled a house. I would like to cut the model for the render. The invisible box is not working, playing with the walls is a little bit time consuming. Are there any other way to do that (like the invisible box was)? |
| Posted by okh at Oct 14, 2015, 9:23:00 AM |
Re: cut the floor for the render If I get what you are trying to do, look in from the side at a room. I would use one of three ways of doing this: 1) Modify 3D view - Walls transparency 2) Select the walls (and everything else on one side with Area select) and set wall height to 20 cm (or something). Then use Undo to get the walls back after you have looked. (Delete does not do the same, as rooms and furniture will disappear too.) 3) If you want the side view often, you could place the elements you want to hide on a new Same elevation level . As long as you have 3D view set to Display selected level , you can simply move between the two levels to "remove" the walls placed on the top level. Neither method is perfect, but #2 works quite nicely for me. Just one swipe with select, Modify walls (Ctrl-Shift-E), set height, Enter. Look and then Ctrl-Z. ok |
| Posted by lilalur at Oct 15, 2015, 4:11:47 PM |
Re: cut the floor for the render Unfortunately on a complicated model modifying the walls height is a real pain. For example: http://www.livingoops.com/wp-content/uploads/...-interior-1-bedroom-5.jpg I was just curious. Is there any easyer way to do this effect or you need to setup the walls one by one. |
| Posted by lilalur at Oct 15, 2015, 4:13:39 PM |
Re: cut the floor for the render but thank you for the shortcut :) that could make it easier. |
| Posted by okh at Oct 15, 2015, 4:33:38 PM |
Re: cut the floor for the render I don't get it. If you use select multiple walls and modify at the same time, surely that change is pretty quick? Either Shift-click several objects, or much easier: area select by clicking outside the walls, hold, move mouse so relevant walls are selected (and whatever else, doesn't matter). After you have selected use Modify walls to change the height of all walls at the same time. And then later, use Undo (Ctrl-Z) to bring them all back. But maybe I am missing something. ok |
| Posted by lilalur at Oct 16, 2015, 4:06:47 PM |
Re: cut the floor for the render When you need a cut it's not always need to include the whole wall. These times you need to break the wall first and then you can do the resize. The problem is when you want to use multiple angle and you need more cut. I don't say its impossible its just unnecessarily complicated compare with the invisible box method what I saw once. You just put a box where it's needed and its hide the walls where you don't want to see them. |
| Posted by Puybaret at Oct 17, 2015, 11:11:12 AM |
Re: cut the floor for the render You could import and use one or more large invisible boxes to cut the walls they will intersect, as in the file attached to this post. Don't forget to select the Door or window at the 3rd step of the import furniture wizard, and then disable magnetism when you move the box so the program doesn't try to place the moved box on the closest wall. Note that those boxes will cut only walls and not other doors and windows, and if you import an invisible box as a staircase it will similarly cut all the floors. ---------------------------------------- ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by lilalur at Nov 1, 2015, 7:32:29 PM |
Re: cut the floor for the render Thank you :) That is what I was looking for. |
| Posted by lilalur at Nov 1, 2015, 7:34:13 PM |
Re: cut the floor for the render Are you planning to make this "invisible box" as an inside feature to hide everything what cross its road? That would be a great additional element. |
| Posted by Puybaret at Nov 1, 2015, 7:37:59 PM |
Re: cut the floor for the render It's such a weird object that I'm reluctant to add it. But like the transparent texture, I understand it's very useful in some cases. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by lilalur at Nov 3, 2015, 3:39:21 PM |
Re: cut the floor for the render Only design matter ;). And invisible box in the official furniture library looks... weird. But a separate box to the top menu where the wall,room,poly...etc are and call it cutting edge is sounds as a feature. You actually can put a transparent blue box with that to your plan and can resize it (or bend it or make it sloping ;) ) and its act like the invisible box does now, hide all the walls (and maybe the doors and the windows as well). Anyway. Thanks again the help. This one of my favourite program to make light but good looking plans :) Fantastic work. |
| Posted by VeroniQ at May 18, 2017, 12:52:04 PM |
Re: cut the floor for the render This new tip in the blog proposes different solutions to this thread. |
Current timezone is GMT Sep 6, 2026, 7:58:26 AM |
