Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to smelt in the wall of the room in the house? |
| Print at Aug 17, 2026, 5:38:07 AM | View all posts in this thread on one page |
| Posted by Hymer at Aug 19, 2015, 3:55:14 PM |
How to smelt in the wall of the room in the house? Hello! I am new here and in Sweet Home. When I make rooms inside the outer walls, the doors and the windows don't penetrate both. If I put a door, it is seeming either the outer or the inner wall. It is only one wall in the reality. How can I smelt in the rooms wall in tha outer wall? Another quedtion: is there any list of the menu items in English? My version is Hungarian and if I want to ask something, it can be misunderstanding. |
| Posted by Puybaret at Aug 19, 2015, 4:38:42 PM |
Re: How to smelt in the wall of the room in the house? The program is not designed to take into account two walls placed beside each other when you move doors and windows. The simplest way is to place and resize each door and window without using magnetism, either by entering their position and depth in the furniture modification dialog box, or with the mouse after you deactived magnetism. The English menu items are available here but maybe it would be easier for you to temporarily change the language used in the program with its preferences. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Hymer at Aug 19, 2015, 8:50:05 PM |
Re: How to smelt in the wall of the room in the house? Thank you, Emmanuel. I tried to penetrate both walls by setting double depth to the window, but it did not work. Isn!t it better to create only walls instead of create rooms? What is the difference between a room created as room or created with walls? |
Current timezone is GMT Aug 17, 2026, 5:38:07 AM |
