Sweet Home 3D Forum » List all forums » » Forum: Developers » » » Thread: Add folder to compile using ant and build.xml |
| Print at Sep 19, 2026, 6:43:38 PM | |
| Posted by lnk7 at Aug 12, 2015, 4:32:40 AM |
Add folder to compile using ant and build.xml Hello I added a folder in the project and would like to know how to add this folder on build.xml to compile the ant to generate the .jar I tried to add <include name = "folder/**"/> under <include name = "src/**"/> in build.xml But the ant does not add it and when you run the jar, the part that depends on the folder does not run. |
| Posted by clanmills at Aug 12, 2015, 12:28:39 PM |
Re: Add folder to compile using ant and build.xml My project (ToWebPlugin.jar) uses two libraries which are not part of SH3D. They are json-simple-1.1.1.jar and ST-4.0.8.jar. I've added them in Eclipse and everything is good for running/debugging from Eclipse. To get ToWebPlugin.jar to "see" the libraries for json-simple and ST at run-time outside of Eclipse, I included a "raw" copy of the classfiles from json-simple and ST in ToWebPlugin.jar I did this using a little bash script which rewrites the ToWebPlugin.jar to include the class trees from json-simple and ST. The script does this: 1 Expands ST and json-simple into the temporary directory (with jar xf) 2 Expands ToWebPlugin.jar into a temporary directory (with jar xf) 3 Generates a new ToWebPlugin.jar from the temporary directory (with jar cf) This has the restriction that ToWebPlugin.jar contains a local copy of the ST and json-simple classfile trees. So, that code isn't shared with SH3D or other plugins. However both ST.jar and json-simple.jar are modest in size and add about 400k to ToWebPlugin.jar which is about 500k before being rebuilt. The redistributable ToWebPlugin.jar is about 900k and works fine on Mac/Windows/Linux. I haven't investigated how to achieve the unpack/repack jar using ant/maven or any of the Eclipse build magic. When I export a new copy of ToWebPlugin from Eclipse, I have to manually run my build script. Automating this from Eclipse is on my (long) TODO list. |
| Posted by lnk7 at Aug 14, 2015, 3:35:47 AM |
Re: Add folder to compile using ant and build.xml It has no way to include the folder by build.xml? I needed to build the build.xml with this folder |
| Posted by Puybaret at Aug 14, 2015, 5:04:29 AM |
Re: Add folder to compile using ant and build.xml The documentation page about Ant javac task gives all the détails you need about its includes attribute. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 19, 2026, 6:43:38 PM |
