Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: Create custom table |
| Print at Aug 16, 2026, 9:09:42 AM | |
| Posted by lodha13 at Aug 10, 2015, 10:20:42 PM |
Create custom table Hi How do we create custom table having 3 layered top. as attached in the image. When I downloaded a few models from http://www.sweethome3d.com/freeModels.jsp I was not able to edit individual pieces in those models. My requirement is after saving the model in obj or sh3d I should be able to edit it when I open it in a different environment. Thanks Abhishek |
| Posted by hansmex at Aug 11, 2015, 12:50:17 AM |
Re: Create custom table The table in the image can be easily made by combining 7 boxes. - 4 narrow, high boxes for the legs - 3 thin boxes for the table top and the two surfaces below it. Give components different colours according to your needs. Then export and import the model as furniture. By using Modify furniture --> Materials --> Modify you can assign different colours or textures to the items you gave different colours during creation. Be careful to use the correct box model. One box model has 6 sides that can be individually altered. If you make your table with this box, you end up with many, MANY individual parts when you change colours/textures. There is a simpler box model where you change all sides in one go. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
Current timezone is GMT Aug 16, 2026, 9:09:42 AM |
