Sweet Home 3D Forum » List all forums » » Forum: Wishlist » » » Thread: Multiple Suggestions <3 |
| Print at Sep 15, 2026, 9:07:06 AM | |
| Posted by Vkbear0 at Jul 31, 2015, 3:40:46 AM |
Multiple Suggestions <3Hello users! I am absolultely in love with this program. I play with this as a hobby (not a profession). I been using this for nearly a year! So far I have noticed these things on my wishlist could come extremely handy. I apologize to developers who may be overloaded with this large list of mine. 1. Crown Molding + Floor Molding I noticed that they have the floor one done. However, I do wish that they could make the top of the wall option as well. 2. Guide to average sizes of utilites? I feel that it would be an excellent use to the users to know default sizes of anything they put into their house. What you think? 3. More Ceiling Options For Example: Beveled ceiling Cathedral Ceiling Dome 4.Automatic Railing Generator I would enjoy the option of creating a floor with a chosen side to have railing. It becomes handy for lofts, balconies, and decks. 5. Skylight/Glass floor option I'm not really sure how else to explain this. But I want this option badly as well. Including it into a automatic roofing generator would be excellent as well. Thank you for reading this! ![]() ---------------------------------------- -The Hobbyist |
| Posted by okh at Aug 4, 2015, 2:11:33 PM |
Re: Multiple Suggestions <3 For some of your ideas there are workarounds (think importing elements as staircases to punch and reshape ceilings and make glass floors, like SF 3D models 308 and so on). 2. Guide to average sizes of utilites? I feel that it would be an excellent use to the users to know default sizes of anything they put into their house. What you think? Finding out correct sizes really does take a lot of time. Annoyingly, dimensions are not that standardised and vary from country to country. For instance, kitchen cabinets are often produced in 40-60-80 cm widths in Europe, similar in the US, but usually in whole inches which means they are not interchangeable.Or to take doors. When ordering from my local dealer, you should specify interior door size by the wall opening, so the actual door is smaller. Door sizes in Europe often (but not always) come in these flavours. Module Frame DoorA staircase is another tricky example with different requirements, often by law. In addition to width, railing and baluster distance stuff, the staircase will usually be within these values Angle: 17° - 42°The best hint may actually to search for actual sizes online with local dealers. In terms of model making, all this means that the best to hope for is that the proportions are approximately correct - and that the model made is within 'normal' ranges. ok |
| Posted by Vkbear0 at Aug 6, 2015, 1:46:05 AM |
Re: Multiple Suggestions <3 I do like the suggestion. I could always look on the shopping websites for sizes as well. I still struggle on the counter-top size and the hall space. I'm not entirely sure what is the generic sizes for them either. I will figure that part out though! I can make a guide too maybe ![]() ---------------------------------------- -The Hobbyist |
| Posted by Vkbear0 at Aug 26, 2015, 3:53:50 AM |
Re: Multiple Suggestions <3 I found this by the way. http://www.appliancesizes.com/ seemed to help my US sizes ![]() ---------------------------------------- -The Hobbyist |
| Posted by okh at Aug 26, 2015, 11:46:22 AM |
Re: Multiple Suggestions <3 Useful link, showing that the standardized round numbers are similar in Europe and the US, but not the same. And there are some pitfalls when fitting a kitchen. For instance, in Europe base cabinets are often standardised to: 60 cm (23,62") deep (some 56 cm, 22,05") 88 cm (34,65") tall (including legs/support) 40/60/80cm wide. In the US, apparently, the similar base cabinet would be 24" (60,96 cm) deep and so on. In short, a model found online could be similar, but not accurate. Dishwashers, sinks, cooktops etc. are usually sized to fit inside standardised elements. Worktops here usually come in 60-63 cm depths, wall cabinets some 30 to 40 cm deep in different heights. More important, there are minimum safety requirements for the distance between the cooktop and wall cabinet / extractor hood (which means it may be impossible to use the tallest wall-cabinets if ceiling space is insufficient). However, these standards must be taken with a pinch of salt as many suppliers use non-standard dimensions. One local supplier uses worktops/base cabinet depth of 75 for more work-space/storage; another supplier uses 50 cm depth for more floor-space in confined spaces. Also, an international, Scandinavian supplier of kitchens, uses different dimensions in the US and Europe. Brits who visit the US site to get inches, may find that the local store will deliver different dimensions for their kitchen elements. As a couple of mm can make the difference between a perfect fit and lots of extra construction, it is worthwhile doing an extra check to get accurate measurements for SH3D elements. And this is especially important when combining kitchen elements from different suppliers, such as a nice work-top from one and base cabinets from another. SH3D is extremely useful for kitchen decoration (and more useful than some of the kitchen planners on suppliers' websites) provided you can find the right models online. It can be a good idea first to size the kitchen elements correctly, use move with SHIFT-CTRL to place and then Furniture-Align side by side to get the correct fit. ok ![]() |
| Posted by Vkbear0 at Sep 19, 2015, 10:33:31 AM |
Re: Multiple Suggestions <3I also found another request that I would like. I noticed that adding the ceiling lights option tends to make the render for the windows work better. However, there is random black spots and random placements of the ceiling lights in the rooms. I would like to be able to re-arrange the lighting somehow. In other words, Under add ceiling lights there would be the button called Advanced Lighting Options? ---------------------------------------- -The Hobbyist |
| Posted by Puybaret at Sep 20, 2015, 12:25:00 PM |
Re: Multiple Suggestions <3 Ceiling lights are not placed randomly, but in the center of rooms. If you don't want them, just unselect the Add ceiling lights check box in the photo creation dialog box. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by okh at Nov 16, 2015, 9:22:06 AM |
Re: Multiple Suggestions <3 I found this by the way. http://www.appliancesizes.com/ This link from the Loeb Drama Center at Harvard can be useful for getting proportions right. And of course, just searching for anthropometry / ergonomics, will give idea about how to scale objects correctly. ok |
Current timezone is GMT Sep 15, 2026, 9:07:06 AM |
