Sweet Home 3D Forum » List all forums » » Forum: 3D models and textures » » » Thread: problem with lighting effects |
| Print at Aug 14, 2026, 1:10:11 AM | |
| Posted by SKYFLIGHT at Jun 12, 2015, 9:58:50 PM |
problem with lighting effects Hello, again I remind you that do not speak English and this message performed with google translator. I'm trying to make a disco, but I find the lighting problem. I would like to know so I can make lights that have projection to give the effect of a disco. From already thank you very much |
| Posted by hansmex at Jun 13, 2015, 9:52:18 AM |
Re: problem with lighting effects I sent you a file I made a few years ago. Maybe it helps. Hans ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by santbose at Jun 15, 2015, 8:20:47 AM |
Re: problem with lighting effects Hi Hansmex can you upload the same in Sourseforge or in the forum for others to use if they are interested. Thanks in advance. |
| Posted by hansmex at Jun 15, 2015, 12:10:12 PM |
Re: problem with lighting effects I can, but I won't. I've sent the file to the email address in your profile. H ---------------------------------------- Hans new website - under constuction hansdirkse.info |
| Posted by Ni_cola79 at Jul 27, 2015, 10:47:43 PM |
Re: problem with lighting effects Hello to all. I'm new to the forum , but not the program .. I was wondering if I could get myself some more information about the problem in question . And again, if there is ' some function ' which decreases the light in a particular room . Thank you in advance. |
| Posted by okh at Jul 28, 2015, 10:38:07 AM |
Re: problem with lighting effects Short answer: yes, disable "Add ceiling lights " when rendering, and add lightsources to each of the rooms in the plan. Each light source can be dimmed in properties. Long answer: When you render a photo or video, the light comes from several sources: 1) You will get sunlight according to the time of day (and day of the year). This will change according to the clock and date settings. 2) You can get simple interior illumination with an option to "Add ceiling lights " in "Create photo / video " menus. 3) But you can also add light sources in your plan: see the furniture catalogue and look for "Lightsource" (Incandescent, Fireglow, Red, White etc). These are invisible lamps that can be placed around in the rooms, and their strength can be adjusted in the properties. 4) In addition there are models with specific SH3D light source properties (like this) which can be dimmed just like the light sources in the catalogue. (More info - see e.g.thread 4765). ok |
| Posted by DonutGa at Oct 12, 2015, 1:15:15 AM |
Re: problem with lighting effectsHi Hans , I read this, and also need the file , as did also a disco - bar , but failed to lighting effects , you could send the file by mail? Thank you |
Current timezone is GMT Aug 14, 2026, 1:10:11 AM |
