Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: sweethome3d-4.6-linux-x64.tgz |
| Print at Sep 6, 2026, 6:02:57 AM |
| Posted by tylla at Nov 18, 2017, 11:48:06 AM |
Re: sweethome3d-4.6-linux-x64.tgz Sorry for resurrecting such old thread, but as I was greeted with this same error when installing the recent (5.6) version on Debian Stretch (9.2) I thought I give a try to find some solution. While the suggested workaround (nomodeset) might work for some, I have found another solution which might be better suited. The last solution to this SO question (which seems the same problem) suggests a workaround in code that consists of a few lines of code. Maybe you could give it a try. I am willing to help in testing if needed. |
| Posted by tylla at Dec 26, 2017, 2:20:46 AM |
Re: sweethome3d-4.6-linux-x64.tgz As it turned out the suggested workaround (nomodeset) causes several unwanted behaviors on my Lenovo X201 so I had to disable it. After several hours of trials, I found out the solution to this problem. The root of the problem (according to my best understanding) is a bug in Java (see https://bugs.openjdk.java.net/browse/JDK-8173853). This has been fixed in Java 8u152 and 9 (see https://bugs.launchpad.net/ubuntu/+source/xorg-server/+bug/1232471). So the solution is to update your Java. In my setup this involved a little bit of extra work as I don't like to litter my hard drive with installed programs that the package manager is unaware of, but finally it is working. |
Current timezone is GMT Sep 6, 2026, 6:02:57 AM |
