Print at Oct 1, 2026, 2:24:33 AM View all posts in this thread on one page
Posted by oakland602 at May 8, 2015, 6:53:30 AM
How to delete remove hide dimensions
I've been using "create dimensions" to measure items, to get them a certain distance from the wall for example.
When I'm done with the dimensions, how do I get rid of them?
Posted by hansmex at May 8, 2015, 11:14:07 AM
Re: How to delete remove hide dimensions
Try this:
1 - select dimension
2 - press Delete
Posted by oakland602 at May 8, 2015, 4:16:45 PM
Thanks Hansmex,
I'm needing some help with step 1. How do I select dimension? Every time I try it, I end up moving my floor or something else. I've tried clicking on the numbers with the select tool, and I've tried using the dimension tool. What am I missing?
Posted by Puybaret at May 8, 2015, 11:31:57 PM
Don't click on the number but on the lines themselves.
Posted by oakland602 at May 9, 2015, 8:59:48 AM
Perfect! That's the trick.
Thanks! Love the software.
Posted by iTwo at Sep 3, 2024, 8:58:10 AM
Is there a way to select ALL dimensions?
Posted by Keet at Sep 3, 2024, 9:12:00 AM
Not that I know of.
The best way to handle this is to always put all dimensions on their own (same elevation) level. That way you can show/hide the level with dimensions or completely delete it.
Posted by Puybaret at Sep 3, 2024, 10:27:04 AM
You could select all the dimensions with Select Hide utilty plug-in developed by Dorin.
