Print at Sep 20, 2026, 10:09:33 AM
Posts: 116   Pages: 12   [ Previous Page | 3 4 5 6 7 8 9 10 11 12 | Next Page ]
Posted by YGYL at Jul 16, 2015, 3:24:21 PM
Re: Sweet Home 3D 5.0
NEW BUG 2 > □
Original Picture
Posted by Puybaret at Jul 16, 2015, 6:41:53 PM
It's probably the character "²" that is missing in the font you chose.
Posted by YGYL at Jul 17, 2015, 4:52:15 AM
applause   Re: Sweet Home 3D 5.0
If you can ,then not find "²" in the font,specify a default "²" would be better.
Posted by Puybaret at Jul 18, 2015, 12:58:59 AM
I wanted to release Sweet Home 3D 5.0 tonight, but can't tag the version in the source code and can't upload installers on SourceForge.net because most of their services have been down for almost one day!
That's why I prefer to host the released files on sweethome3d.com for the moment.
You can download them with the following links:
[Removed old links, go to https://sourceforge.net/projects/sweethome3d/files/SweetHome3D/SweetHome3D-5.0/ to download the files]
Once SourceForge.net will be repaired, I'll upload these files there and will make the release more official on sweethome3d.com.
Thanks for your patience...
Posted by hansmex at Jul 18, 2015, 1:03:28 AM
Thank you once again for a great job !!
Posted by Puybaret at Jul 20, 2015, 1:47:44 AM
As upload service won't still be available on SourceForge.net before a while, I officially released Sweet Home 3D 5.0 files on sweethome3d.com tonight.
Released files will be copied at SourceForge.net, once their service will be back.
Note that the files I released two days ago were updated under the same name at 19:23 CEST on July 19, to fix a bug I found on the visibility of doors and windows in layers lower than the one they belong to. Sorry for any inconvenience redownload may cause.
Thanks for your tests and your great support! smile
Posted by YGYL at Jul 21, 2015, 4:44:22 AM
From the old version to the present, there has been a translation error
Original Picture
新建墙体厚度(F) change to 新建楼层的楼板默认厚度(F)
Posted by yancan at Jul 29, 2015, 6:05:20 PM
Hello Emmanuel,
great piece of software by the way!
Do you have any idea when the portable version of V5.0 will be made available?
Best regards.
Posted by Puybaret at Jul 30, 2015, 11:49:00 AM
Probably not before mid August. The missing data are some sh3l additionnal translations that contributors might have difficulties to update because of SourceForge problems with CVS and other repository features.
But you can update the existing portable version 4.6 to 5.0 by yourself: download one of the Linux installers of version 5.0, uncompress it to get the lib/SweetHome3D.jar file it contains, then replace the file with the same name in the portable version with the 5.0 version file you extracted. That's all!
Posted by yancan at Jul 30, 2015, 7:55:30 PM
Merci beaucoup pour cette technique d'upgrade manuelle !
Cordialement.
