Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to add a lower level to existing two-level design |
| Print at Oct 1, 2026, 3:41:53 AM | View all posts in this thread on one page |
| Posted by bert.struik at Apr 24, 2015, 10:11:57 PM |
How to add a lower level to existing two-level design After creating two levels, how can a lower level be added and essentially move everything already done up one level? I wanted to add the foundation and concrete slab as a level, to show the foundation above base height. Did not think of this until after making the first and second floors. Since I only know how to add a level on top, that would mean moving all the elements of level 0 to level 1 and all the elements of level 1 to level 2. The elements (walls, windows, doors, furniture etc...) do not have a level assignment in their menu data. Do I have to start over? |
| Posted by hansmex at Apr 25, 2015, 6:55:54 PM |
Re: How to add a lower level to existing two-level design - Add a Level - Double-click level tab - Change Elevation to negative value - The tab will move to the left - You created a level lower than the "ground" floor H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by bert.struik at Apr 26, 2015, 4:29:51 AM |
Re: How to add a lower level to existing two-level design Hans: Thank you very much. That worked well. __ Bert |
| Posted by bert.struik at Apr 26, 2015, 9:01:48 AM |
Re: How to add a lower level to existing two-level design When the new level (defaults to level 2) is set to negative height and its tab moves to the left it shows a level 2, 0, 1 sequence. The tabs can be renamed to 2 > 0, 0 > 1 and 1 > 2, to have tabs 0, 1, 2. I did something stupid I guess, because several of the walls from level 2 became lost in the map view. They show up in the 3D aerial view somewhat lower than before. under the level 2 tab walls from level 1 show up instead. |
| Posted by Puybaret at Apr 26, 2015, 1:33:28 PM |
Re: How to add a lower level to existing two-level design In the same dialog box that allows you to change the elevation of a level, you can also change the name of a level. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Oct 1, 2026, 3:41:53 AM |
