Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: No 3D panel with SweetHome 4.5 on Debian Jessie |
| Print at Sep 30, 2026, 9:44:02 PM | |
| Posted by jbernon at Apr 20, 2015, 8:02:22 PM |
No 3D panel with SweetHome 4.5 on Debian Jessie When I open a sh3d file with SweetHome 4.5 on Debian Jessie through Gnome 3.14.1, I can only display de 2D panel. Here are the log messages. Who can suggest anything ? Apr 20 18:49:51 pc-jean-debian sweethome3d.desktop[3760]: Java 3D: implicit antialiasing enabled Apr 20 18:49:54 pc-jean-debian gnome-session[1047]: Window manager warning: Invalid WM_TRANSIENT_FOR window 0x20000ac specified for 0x20000b1 (Mises à j). Apr 20 18:50:37 pc-jean-debian gnome-session[1047]: Window manager warning: Invalid WM_TRANSIENT_FOR window 0x20000ac specified for 0x20000b1 (Mises à j). |
| Posted by hansmex at Apr 21, 2015, 4:10:58 AM |
Re: No 3D panel with SweetHome 4.5 on Debian Jessie Use Ubuntu or Kubuntu 14.04 LTS. I tried Ubuntu Gnome 14.04 and couldn't get SH3D to work at all. Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by jbernon at Apr 21, 2015, 12:39:42 PM |
Re: No 3D panel with SweetHome 4.5 on Debian Jessie Thank you for your answer Hans. I can already use Sweethome through Windoxs 7. I would like to use it through my Linux dist which is the new Debian 8 release (kernel 3.16.2). Using Ubuntu 14 for one app doesn't make sense in my environment. I will try again to make sh3d working with Debian 8 (also called Jessie). sh3d is part of the main dist packages and it should work. Here are the Debian packages : - sweethome - sweethome3d-furniture Here are the sweethome package dependancies : - icedtea-netx-common | sun-java6-bin - javawrappers - libfreehep-graphicsio-svg-java - libitext-java - libjava3d-java - libsunflow-java - libbatik-java - default-jre | java6-runtime In your opinion, what is to be checked in this stuff ? Is there any probability to get it working ? |
| Posted by hansmex at Apr 21, 2015, 12:49:59 PM |
Re: No 3D panel with SweetHome 4.5 on Debian Jessie I've never used Debian, so what I'm telling you is about past experiences with Ubuntu. You could try: - Read the FAQ, there's a note on 2D-3D problems linked to hardware - Update your graphics driver - Uninstall all versions of Java and install Oracle Sun Java - Finally, if the installed version of SH3D doesn't work, maybe the webstart version does. Good luck. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by jbernon at Apr 21, 2015, 2:47:30 PM |
Re: No 3D panel with SweetHome 4.5 on Debian Jessie Thanks Hans, I already succeeded to run my file and get 3D panel with the web version. I just had to install the java plugin of iceweasel. This was not part of the standard installation. I will look later at the local running, but I will give a return. Bye |
Current timezone is GMT Sep 30, 2026, 9:44:02 PM |
