Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Level value can not be -2000 (cm). |
| Print at Oct 1, 2026, 3:42:44 AM | |
| Posted by macktheknife at Apr 16, 2015, 6:37:23 PM |
Level value can not be -2000 (cm). It seems that the maximum negative value for a level is -1000. This value I can only reach by using the spinner and pressing it down for a long time. With the keyboard I can only enter -200 as maximum negative level value, more negative values are not accepted! Is this a bug? I need my cellar to start at -2000 (cm). Is there any way to do this? I am running the newest mac version available in the Apple AppStore (Version 4.6.2). Screenshot: Thanks!! |
| Posted by slimpy at Apr 17, 2015, 11:24:13 AM |
Re: Level value can not be -2000 (cm). Just to make sure: Your basement starts at 20 meters (eq. 2000cm) below ground? And your ground and first floors are also 20m in height? If that's the case I'm really curious what kind of a project you're designing! Best, slimpy |
| Posted by macktheknife at Apr 17, 2015, 5:30:48 PM |
Re: Level value can not be -2000 (cm). You are right!!! I am so stupid - sorry :-( 2m = 200cm... thats what I wanted to do :-) Thank you!! |
| Posted by slimpy at Apr 17, 2015, 6:29:40 PM |
Re: Level value can not be -2000 (cm). Don't worry! I'm still curious about your project - 2m is a very low ceiling. About the height of a standard door frame. Best, slimpy |
| Posted by macktheknife at Apr 17, 2015, 6:54:39 PM |
Re: Level value can not be -2000 (cm). Yes, the ceiling is very low. In reality it is 2,20m or 2,30m I think. But I need to measure it first. I just started designing the building with 2m, later I will correct that value. Have a nice weekend :-) bye |
Current timezone is GMT Oct 1, 2026, 3:42:44 AM |
