Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Bad picture quality on lv3 |
| Print at Aug 16, 2026, 1:46:21 AM | |
| Posted by gruby33 at Mar 24, 2015, 12:33:03 AM |
Bad picture quality on lv3 Hello. I make room in SH3D. A take a picture and chose lv3. On lv3 always is bad image quality (noise). On lv1 and lv2 and lv4 (creates 20min...) it`s all OK. Ultrabook HP, i5-4200U, HD4400, 4GB RAM, Win 8.1 Pro 64bit. P.S Image from lv3: https://www.mediafire.com/convkey/e1a4/q5oy3ms263eha8w6g.jpg |
| Posted by Puybaret at Mar 25, 2015, 9:36:31 AM |
Re: Bad picture quality on lv3 A better quality would make it much slower to compute. If ever, you want to improve quality settings of level 3, you can compute a larger a image and reduce its size with an image tool. You can also set the properties com.eteks.sweethome3d.j3d.PhotoRenderer.lowQuality.antiAliasing.min to 1 and com.eteks.sweethome3d.j3d.PhotoRenderer.lowQuality.antiAliasing.max to 2, as suggested here. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by gruby33 at Mar 26, 2015, 11:07:35 PM |
Re: Bad picture quality on lv3 Thanks. This is it :) |
| Posted by carlob at May 20, 2015, 3:29:43 AM |
Re: Bad picture quality on lv3 hy puybaret sorry but i don't understand where i can change the properties for high resolution, i see your posted link but i don't know what have i do, i have to create a file ini? and if yes, where i have to put it? thank a lot |
| Posted by Puybaret at May 20, 2015, 10:46:41 AM |
Re: Bad picture quality on lv3 Did you try to change the width and height in pixels to a much higher value? This is the easiest way to remove noise, even if not the most efficient (in terms of required computer power). ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Aug 16, 2026, 1:46:21 AM |
