Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Insert Windows on walls |
| Print at Oct 1, 2026, 12:51:58 AM | View all posts in this thread on one page |
| Posted by Lumaja at Feb 11, 2015, 3:38:08 PM |
Insert Windows on walls Import a window Modified the sizes and drag to the top of 90cm high horizontal Wall, when the drag touches the wall it turns vertical and not possible to insert. With different window the action is different, dragging to the wall I can insert inside or outside but not on a wall, I had no problem with doors. Can please some one explain what I am doing wrong. Thank you |
| Posted by hansmex at Feb 11, 2015, 4:51:08 PM |
Re: Insert Windows on walls When you import a door or window, you have to put a check mark in the box where it says Door/Window. This basic stuff is covered in the User's Guide .... ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
Current timezone is GMT Oct 1, 2026, 12:51:58 AM |
