Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: Solid shape imported from GoogleSketchUp is not shown as expected |
| Print at Sep 30, 2026, 10:36:06 PM | View all posts in this thread on one page |
| Posted by cspal at Feb 8, 2015, 7:58:02 PM |
Solid shape imported from GoogleSketchUp is not shown as expected Hello, I made a house.sh3d model and the roof was imported from a GoogleSketchUp model. However, when in SweetHome3D, the roof is not shown as expected because one can't see it's all sides but only the opposite sides from the view point. It is shown like the slooping ceiling. So if I rotate the house in 3D view I can see only the opposite sides of roof. How can I solve this problem? Regards, from Pál |
| Posted by Puybaret at Feb 8, 2015, 8:23:21 PM |
Re: Solid shape imported from GoogleSketchUp is not shown as expected Did you try to select the Invert back and front faces check box at the second step of Furniture import wizard? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by cspal at Feb 8, 2015, 9:12:25 PM |
Re: Solid shape imported from GoogleSketchUp is not shown as expected No, I did not. But right now I can't to try it out, because the roof DAE / Collada model is not here on my computer. Soon as I have it I shall try it out. Thanks! |
| Posted by hansmex at Feb 8, 2015, 10:45:24 PM |
Re: Solid shape imported from GoogleSketchUp is not shown as expected Even a better solution: - when exporting from Sketchup, select Options - make sure that Two Faces is checked (not sure how it's called exactly) - then export as DAE Do this with all models you export from Sketchup. SH3D sometimes has difficulty showing the correct face, resulting in the kind of probem you have. ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by okh at Feb 9, 2015, 9:52:45 AM |
Re: Solid shape imported from GoogleSketchUp is not shown as expected On a related note, if you have made your own roof (or edit one), you should make sure you apply the same texture to both sides of the roof surfaces. If not you risk that the other side bleeds through when rendering. ok |
| Posted by cspal at Feb 10, 2015, 1:44:53 PM |
Re: Solid shape imported from GoogleSketchUp is not shown as expected Even a better solution: - when exporting from Sketchup, select Options - make sure that Two Faces is checked (not sure how it's called exactly) - then export as DAE Do this with all models you export from Sketchup. SH3D sometimes has difficulty showing the correct face, resulting in the kind of probem you have. Indeed, this way the roof is look right: Thanks! |
Current timezone is GMT Sep 30, 2026, 10:36:06 PM |
