Print at Oct 1, 2026, 12:53:06 AM
Posted by bugarski.nenad at Feb 8, 2015, 12:09:37 PM
arch on half round wall
does anyone know how can i make/drow arch on a half round wall? tnx
Posted by okh at Feb 8, 2015, 11:42:32 PM
Re: arch on half round wall
After you have drawn a wall with correct endpoints, double-click (or select and Modify walls) to enter Arc extent in the wall properties. ok
Posted by bugarski.nenad at Feb 22, 2015, 12:53:31 PM
that makes a half round wall. i know that. what i want is to make arch hole in that kind of wall...
Posted by changoel at Jan 10, 2017, 5:21:10 AM
me too
Posted by bdfd at Jan 10, 2017, 5:22:36 PM
If I understand correctly, you want to do that ?
If yes, you can use the default object 'arch'.
if no, you must create two walls* which will export in obj format.
You import again the new object and when you see the green arrows, click on up right frame (front view) and then with the mouse and key shift click on the down green Arrow to have 90° and click enter...
You'll have your half arch, see the joined file below.
(*) First wall : standard
Second wall : same than first but 'arc extent' = 90° and joins the twice.
Attachment Half arch.obj (12572 bytes) (Download count: 10532)
Posted by Miker777 at Jan 10, 2017, 10:11:26 PM
If you want to put the arch IN the curved wall, then i think you can create your wall, give it an arc, then position an arch , from the library, but turn the magnetism OFF, make the arch as big as is needed to create the opening.
Posted by Miker777 at Jan 10, 2017, 10:43:55 PM
Tried it and failed sorry, the opening that is created is rectangular, i will have a rethink.
Posted by Miker777 at Jan 10, 2017, 11:54:05 PM
I managed to make some thing that might do you, or at least give you an idea how you might achieve what you desire, here is a link to a sh3d file.
Posted by Puybaret at Jan 15, 2017, 4:20:04 PM
Nice attempt Mike. Of course, this workaround will work more or less well, according to the width of the arch and the curve of the wall...
Posted by Miker777 at Jan 15, 2017, 8:30:29 PM
I know EP, but its all i could think of sad
Posted by Puybaret at Jan 15, 2017, 9:11:59 PM
If this feature was easy to draw, it would be in Sweet Home 3D itself wink
But who knows, support of non rectangular door or windows placed on round walls might appear one day. As a round wall is actually approximated as a series of small straight walls, it could be not so difficult to adapt the program and support this feature.
Posted by Miker777 at Jan 18, 2017, 7:08:12 PM
Your not wrong Emmanuel, but its the challenge smile
Posted by jscross at Apr 27, 2017, 5:41:30 PM
Possible solution to the question, for creating such a wall. I created a Youtube video, showing my process to resolve this type of question.
https://youtu.be/cmixugW-kYs
Hope this help other users.
John
