Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Cannot render in level 4 (best) |
| Print at Sep 20, 2026, 11:38:42 AM |
| Posted by kurucom at Jan 30, 2015, 4:22:30 PM |
Cannot render in level 4 (best) My computer has: AMD FX8320 (8 core @ 3.5 GHz) AMD 280X (3 GB) 16 GB RAM (4x4 GB) 256 GB SSD (Ocz Vertex 4 - only 1 partition and 109 GB empty) 4 TB HDD (Seagate barracuda 7200.14 - only 1 partition and 806 GB empty) Windows 8.1 64 bit (very stable and has all updates) Java version 8 update 31 (64 bit) SweetHome3D.l4j.ini contains 2 lines -Xmx16384m -Xms3072m I am trying to render in best level but cant do it, even small object (fx. only one table in scene) Level 1, 2 and 3 works fine but on 4 (best level) nothing happens Sorry for my bad english.... |
| Posted by hansmex at Jan 31, 2015, 11:56:01 AM |
Re: Cannot render in level 4 (best) What does Help --> About say? Something like: Java version 1.6.0_45 / 32 bit / 0.6 GB max H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by kurucom at Jan 31, 2015, 3:05:29 PM |
Re: Cannot render in level 4 (best) What does Help --> About say? Something like: Java version 1.6.0_45 / 32 bit / 0.6 GB max H Help -> About Says: Java versiyonu 1.6.0_45 / 64 bit / 14,2 GB max ;) |
| Posted by Puybaret at Feb 2, 2015, 3:47:06 PM |
Re: Cannot render in level 4 (best) Where did the table come from? Wouldn't you have used a too large image as texture somewhere? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by kurucom at Feb 2, 2015, 3:55:54 PM |
Re: Cannot render in level 4 (best) I dont remember, I have too much objects imported from Sketchup, 3DMax etc.... But I am trying to render what I seen in this forum happens nothing. I am creating new file with only one table it hapens nothing to. |
| Posted by Puybaret at Feb 5, 2015, 7:39:47 PM |
Re: Cannot render in level 4 (best) Send me your file if you want. Maybe you encountered a bug. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by kurucom at Feb 7, 2015, 8:57:48 AM |
Re: Cannot render in level 4 (best) Sent... Thank you very much... |
| Posted by Puybaret at Feb 8, 2015, 8:52:33 PM |
Re: Cannot render in level 4 (best) I've been trying your file on my iMac with no issue using -Xmx2250m. Could you try again with Sweet Home 3D version 4.6 and no SweetHome3D.l4j.ini file? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by kurucom at Feb 9, 2015, 8:20:16 AM |
Re: Cannot render in level 4 (best) Finally found the problem I changed only Language and now everythings work. Maybe you should check language file. |
| Posted by Puybaret at Feb 9, 2015, 4:24:20 PM |
Re: Cannot render in level 4 (best) Would you use Turkish localization? Last week, after releasing the version 4.6, I found a bug that prevented to run the rendering at the best quality with Turkish localization. Correction will be available in the next version. Sorry for the issue. If you prefer to run Sweet Home 3D in Turkish, I can provide a patch if needed. Just open a bug ticket and I'll post the patch there. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 20, 2026, 11:38:42 AM |
