Print at Oct 1, 2026, 2:57:49 AM
Posted by pseudo_relic at Jan 20, 2015, 4:55:16 AM
smile   Extending Memory : Not working
First of all, kudos to Emmanuel and SH3D co-developers for creating such an amazing software. I have been using it for last 2 months and I find it very useful.
In order to share my designs I am creating Q4 quality (Best) photo realistic renderings of the houses I have built in SH3D. Everything works fine but these rendering are very slow.
I would really like to speed up the Photo Realistic rendering process. I have tried extending the memory using the technique mentioned in http://www.sweethome3d.com/support/forum/viewthread_thread,1460, following are the results:
Windows 8.1
a. Created a text file named SweetHome3D.l4j.ini in the same directory as SweetHome3D.exe, and wrote the max memory Java option (-Xmx2048m) in that file - No effect on speed of photo realistic image renderings
b. Created a text file named SweetHome3D.l4j.ini in the same directory as SweetHome3D.exe, and wrote the max memory Java option (-Xmx4096m) in that file - No effect on speed of photo realistic image renderings
Linux(Ubuntu 14.04)
a. Edited SweetHome3D script and update the 1024 value in the option to -Xmx2048m - No effect on speed of photo realistic image renderings
b. Edited SweetHome3D script and update the 1024 value in the option to -Xmx4096m - No effect on speed of photo realistic image renderings
I even tried adding start memory Java option (-Xms2048m) independently as well as along with above mentioned changes but no luck.
Kindly let me know how to enable the extended memory changes and whether I am missing something.
Thanks in advance.
Posted by Puybaret at Jan 20, 2015, 9:41:17 AM
Re: Extending Memory : Not working
Don't hope miracles from increasing max memory.
When you change -Xmx value, is its value displayed in the About dialog box updated accordingly?
