Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Added furniture in the basement has rendered extra walls to the ceiling |
| Print at Sep 28, 2026, 6:21:12 AM | View all posts in this thread on one page |
| Posted by piotr58 at Jan 18, 2015, 9:41:50 PM |
Added furniture in the basement has rendered extra walls to the ceiling Not sure how to add a screen shot. There are extra walls in the back of the piece, looks like it is pulling something from the ground level. Basement has negative elevation. Using 4.5 |
| Posted by shrlzi at Apr 12, 2021, 6:21:09 PM |
Re: Added furniture in the basement has rendered extra walls to the ceiling Help! I am having the same problem 6 years later. Is there really no solution??? |
| Posted by hansmex at Apr 12, 2021, 10:17:39 PM |
Re: Added furniture in the basement has rendered extra walls to the ceiling You need to give more information to get an answer... Operating system, version, maybe a picture? H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by snmavronis at Apr 17, 2021, 11:51:14 PM |
Re: Added furniture in the basement has rendered extra walls to the ceiling I had that happen in my living room where I was ready put by staircase in an opening I reserved to the side of it. Nothing to do with furniture though, you probably noticed what had already there before. The adjacent room area was the problem. Backup first by saving as a new SH3D file. You can delete the basement "room" and create a new room (define your elevations afterwards) by manually drawing the replacement room shape. Draw around the where the walls go for the basement shape, you can use the upper level outline as a guide. Anyway that fixed my problem when it was rendering angled triangle planes from floor to ceiling across my room. ---------------------------------------- Steve N Mavronis - Retired PC Tech |
| Posted by snmavronis at Apr 17, 2021, 11:52:36 PM |
Re: Added furniture in the basement has rendered extra walls to the ceiling I forgot to add all your furniture can stay in place while you try what I suggest. ---------------------------------------- Steve N Mavronis - Retired PC Tech |
Current timezone is GMT Sep 28, 2026, 6:21:12 AM |
