Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: Floor color and texture not rendering properly |
| Print at Sep 28, 2026, 6:22:17 AM | |
| Posted by Gregh at Jan 18, 2015, 9:23:14 PM |
Floor color and texture not rendering properly Hello For some reason the texture applied to my floor ("Plancher" --> "texture") does not render properly (see screenshot below). Issue is the same no matter what floor texture or color I choose. Strange thing is that it used to work but stopped working at some point. Here is a link for the sweet home 3D file for your reference. I'm using a macbook pro 2014 with yosemite. Thanks for your help ![]() |
| Posted by hansmex at Jan 18, 2015, 10:58:24 PM |
Re: Floor color and texture not rendering properly Looks normal on my computer (Win7 64 bits). Probably a problem with OSX and Java, as reported often bedore. H ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by Puybaret at Jan 19, 2015, 3:56:35 PM |
Re: Floor color and texture not rendering properly I'm aware of this issue and after the multiple improvements I programmed to ensure room cutting in the ground is correct, I noticed it still happens only under Mac OS X with Java 6 from time to time. As it works correctly with Java 6/7/8 under other systems, and also with Java 7/8 under Mac OS X (i.e. with the Java Web Start version), I'm not that motivated to continue trying to fix this issue since it must be a problem in Apple Java itself. Note that the issue appears only at ground level when you're far away and it doesn't appear in photo creation tool. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 28, 2026, 6:22:17 AM |
