Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Need to deploy on Tomcat serer |
| Print at Aug 22, 2026, 1:04:08 PM |
| Posted by prabath at Jan 13, 2015, 6:02:41 AM |
Re: Need to deploy on Tomcat serer Thanks for your reply |
| Posted by prabath at Jan 16, 2015, 4:58:31 AM |
Re: Need to deploy on Tomcat serer I changed the source code to auto load the Floor Plan to the grid. It was successful when I ran the system as a Applet Application. But when I tried to Run as a web application, it doesn't work. Please help to sort out this issue. |
| Posted by Puybaret at Jan 16, 2015, 8:50:58 AM |
Re: Need to deploy on Tomcat serer How could I guess what you programmed??? Why not trying the defaultHome applet parameter? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by charles0215 at Jan 23, 2015, 4:04:30 AM |
Re: Need to deploy on Tomcat serer Thanks for these infos !!! |
| Posted by prabath at Jan 27, 2015, 12:47:37 PM |
Re: Need to deploy on Tomcat serer Hi Puybaret I went through the code you written. It's amazing work u have done. I want to do 1 more thing just to hide the 3D view. Can you pls tell me how to do that |
| Posted by Puybaret at Jan 27, 2015, 6:38:17 PM |
Re: Need to deploy on Tomcat serer In a subclass of AppletApplication, you should override getViewFactory method to return a view factory (for example an instance of a subclass of SwingViewFactory) with a createView3D method that will return null. Then, in a subclass of SweetHome3DApplet, override the method getApplicationClassName to return the name of the subclass of AppletApplication you programmed. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by prabath at Jan 28, 2015, 5:56:47 AM |
Re: Need to deploy on Tomcat serer Thank You Puybaret.. |
| Posted by prabath at Jan 29, 2015, 8:18:52 PM |
Re: Need to deploy on Tomcat serer Hi Puybaret.. I want to add a button next to ZOOM OUT buttons. Please tell me how to add button. I found below link. Some method do not exist in that class. http://www.sweethome3d.com/support/forum/view...F1D4E82105E7F6C79DF1A2202 Thank You |
| Posted by Puybaret at Jan 29, 2015, 9:40:29 PM |
Re: Need to deploy on Tomcat serer Prabath, you request a lot of information but don't give any info to the community about the project you work on. It would be nice to present what you want to achieve, no? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by prabath at Jan 30, 2015, 1:36:59 AM |
Re: Need to deploy on Tomcat serer :) I'm very sorry Puybaret. I'll explain. I'm developing a online System for the Electricians to design Lights, Sockets and A/C systems for a selected Floor Plan. The application reads the PDF files and can detect the Floor Plans. Floor Plans are loaded with fixed scale. 3D view is not available. It is going to be handled by a separate button. So I struggled to add a new Button but failed. |
Current timezone is GMT Aug 22, 2026, 1:04:08 PM |
