Print at Aug 22, 2026, 6:06:31 AM View all posts in this thread on one page
Posted by naskar at Nov 20, 2014, 8:44:35 PM
4.5 Portable Version asking por JAVA in MAC OS
Hi!
I've downloaded the portable version (4.5) os sweet home 3d, since it appears to work without JAVA installed in my system.
However when I start the app, it claims to install JAVA SE 6.
How can I fix this? (I don't want to install JAVA on my system)
I'm running OS X 10.9.5
Thank you!
Posted by Puybaret at Nov 20, 2014, 11:33:58 PM
Re: 4.5 Portable Version asking por JAVA in MAC OS
In the case of Mac OS X, it requires to install Java 6. If you don't want to install it, then don't use the portable version.
Posted by naskar at Nov 21, 2014, 12:05:00 AM
Thanks for the response.
Is there any version bundled with java?
By the way, congrats for the app!!
Posted by Puybaret at Nov 21, 2014, 8:47:35 AM
A free version bundled with Java doesn't exist under Mac OS X yet, but I really don't see the problem to install Apple Java 6. Mac OS X 10.9 used to propose to install Java 6 after user confirmation, while Mac OS X 10.10 makes it less easy by sending the user to a page where he can download Java 6. Installing Java 6 won't put your computer at risk, since it can be used only for applications and not for applets in web browsers which encountered some security problems in the past years. I could bundled Oracle Java 7 or 8 like I did for the Mac App Store version, but creating one application able to switch between Oracle Java and Apple Java depending on the environment isn't easy. Maybe in the next version...
Posted by naskar at Nov 21, 2014, 9:05:54 AM
Ok, thank you very much!
