Sweet Home 3D Forum » List all forums » » Forum: Installation » » » Thread: Sweet Home 3D with Java Web Start not working in java7 |
| Print at Sep 6, 2026, 5:15:32 AM | View all posts in this thread on one page |
| Posted by maaheyindian at Oct 9, 2014, 1:59:31 PM |
Sweet Home 3D with Java Web Start not working in java7Tried in many ways, still no improvement (JNLPSigningException) java7 error retaining… Loosing hope. Any help? ![]() |
| Posted by Puybaret at Oct 10, 2014, 10:36:57 AM |
Re: Sweet Home 3D with Java Web Start not working in java7 This error means that the JNLP file you deployed isn't the same one as the one included in SweetHome3DJavaWebStart.jar file (see target javaWebStart in build.xml ) ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by maaheyindian at Oct 14, 2014, 3:03:36 PM |
Re: Sweet Home 3D with Java Web Start not working in java7 Both files are same; really i don’t know what I am missing here. can you explain me how to get rid of this error.. |
| Posted by maaheyindian at Oct 14, 2014, 3:04:42 PM |
Re: Sweet Home 3D with Java Web Start not working in java7 also working fine in java6... |
| Posted by Puybaret at Oct 14, 2014, 4:56:54 PM |
Re: Sweet Home 3D with Java Web Start not working in java7 It's normal that it works with Java 6, since the verification with JNLP-INF/APPLICATION.JNLP file was introduced with Java 7. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by maaheyindian at Oct 15, 2014, 12:29:51 PM |
Re: Sweet Home 3D with Java Web Start not working in java7 Please give me the right solution; I stuck up on this stage, need help to move forward. |
| Posted by Puybaret at Oct 15, 2014, 2:19:51 PM |
Re: Sweet Home 3D with Java Web Start not working in java7 Please give me the right solution Do you really think that if I knew the solution, I wouldn't give it??? I gave you the hints I could guess, it's up to you to go forward now.---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 6, 2026, 5:15:32 AM |
