Sweet Home 3D Forum » List all forums » » Forum: Features use and tips » » » Thread: How to update the Viewer (Online) correctly? |
| Print at Sep 15, 2026, 11:55:56 AM | View all posts in this thread on one page |
| Posted by Pixelwizard at Oct 9, 2014, 6:45:06 AM |
How to update the Viewer (Online) correctly? Good morning! Actually i'm a little bit irritated - maybe to early to think clear ;) My problem is how to correctly update the viewer. As i keep all components of sh3d up-to-date i'd like to solve also the certificate issue with the viewer version BEFORE 4.4. I created some models, put them to my webserver and anything works fine. one day the certificate was not longer available which means in any browser (firefox, chrome, ie) the models (created in older version than 4.4) wasn't longer visible and the browsers puts some error-messages. all new models works fine online and local - so i just thought, putting the new viewer to the server might help solve the problem. but looks that files from older version still produce problems - so should i open and save them again in version 4.4 of sh3d? i cleared all caches, but just the new files runs properly and as expected, the old ones actually just producing a java-error message and are not visible. maybe i just forgot a small step? regards, alex ---------------------------------------- WIN10 Pro 64bit * 16 GB RAM * AMD FX 6100 * Geforce GTX 660 |
| Posted by Pixelwizard at Oct 9, 2014, 6:59:06 AM |
Re: How to update the Viewer (Online) correctly? forgot the error messsage: securityexeption: JAR should not contain JNLP-INF/APPLICATION.JNLP i just opened the old files, save them again and put them back to the server. ---------------------------------------- WIN10 Pro 64bit * 16 GB RAM * AMD FX 6100 * Geforce GTX 660 |
| Posted by Puybaret at Oct 9, 2014, 8:07:08 AM |
Re: How to update the Viewer (Online) correctly? Looking at the differences between versions 4.4 and 4.1 of the viewer HTML file, you'll see that a new parameter named jnlp_embedded appeared as explained at the end of README.TXT file. Did you add it to your own web site? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 15, 2026, 11:55:56 AM |
