Print at Sep 28, 2026, 7:08:31 AM View all posts in this thread on one page
Posted by sree.arun.kr at Sep 21, 2014, 6:10:44 PM
Need a little help.!
Hello Sir,
Recently I faced a situation like I need to restore my windows to an old restore point, after it I re-installed java JRE 7 to JRE 8. Now on start up SH3D hanging my system like it uses real time priority and took 40 sec to 1 min for full loading.Also when I rotate 3d view it skips frames like a high end game runs in slower system.And also when the application closed the SH3D window disappears but it runs in background I need to end the process through task manager.(If does not drawn or changed anything it closes perfectly).
Re installing java or increasing -Xmx1024m to -Xmx1280m does not solved.
My system configuration is Windows 7 SP1 32bit,with 2GB RAM and 2GB GPU memory.
Posted by Puybaret at Sep 22, 2014, 10:55:00 AM
Re: Need a little help.!
What version do you run? The installer version or the Java Web Start version?
Posted by sree.arun.kr at Sep 22, 2014, 3:58:46 PM
SH3D Installer version 4.4 and also SH3D 4.5beta6(web start?. I don't know.!) jp2launcher.exe failed to close.Not all the time but most. thinking
Posted by Puybaret at Sep 23, 2014, 10:26:57 AM
The Beta version is running with Java Web Start and the JRE you installed.
The installer version works with a private copy of a JRE 6.
Do you see the same issues with both versions?
Posted by sree.arun.kr at Sep 23, 2014, 1:47:56 PM
Less frame rate while rotating is only with installer version.
But application failed to closed is in both version.I mean when draw something and closed without saving or working with a big project(I am not sure exactly how.) rolling eyes
Posted by Puybaret at Sep 24, 2014, 11:37:37 AM
Does the problem appear on any home?
Posted by sree.arun.kr at Sep 24, 2014, 6:44:35 PM
I don't get you.
What do you mean by 'any home'.
Looks like its a problem related with SH3D and java because the closing bug happens in older installer version 4.3 also. d oh
Posted by Puybaret at Sep 24, 2014, 7:18:36 PM
By any "home", I mean any "file".
Posted by sree.arun.kr at Sep 24, 2014, 7:41:23 PM
Yes.
Here attached a sample file (but i don't think it will solve the issue).
1. Open SH3D 4.4 installer version.
2. Loaded a file from resent/history.
3. Just rotated scene (frame skipping bug)
4. Changed time in photorenderer.
5. Saved the rendered image.
6. SH3D closed without saving.
7. 5 minute later open Task manager and it shows sh3d running background.(Runs in background bug) sick
Attachment test.1.zip (571286 bytes) (Download count: 646999) (Sample attachment.)
Posted by sree.arun.kr at Sep 26, 2014, 5:35:05 PM
sad   Re: Need a little help.!
Does this program requires any dotNet Framwork to run properly?
