Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: 3D blank on 1 project while working on other projects |
| Print at Sep 28, 2026, 5:10:09 AM | View all posts in this thread on one page |
| Posted by eeeehaw at Sep 18, 2014, 8:37:45 PM |
3D blank on 1 project while working on other projects I recently downloaded SW v4.4 Full Install (with Java 1.6.0_45/32b) and successfully created a couple projects over the past several days that have been displaying, printing, and saving as PDF docs just fine. Suddenly, I have one of those project files that (1) does not display/render the 3D image at all (the 3D window still exists but is blank), and (2) will not save as a PDF. It does, however, still display the floorplan correctly and allows changes to that floorplan. Closing SW and re-opening that project file does not recover correct behavior, while re-opening my other project file works well as desired. It appears that some type of corruption may have occurred to the non-working project file, but I cannot determine how to resolve the problem with that file. Win7 Ultimate 32b with latest updates, Nvidia Ge510 with latest driver, 4GB system RAM, Java mem set to 600MB (default?) |
| Posted by Puybaret at Sep 19, 2014, 6:19:22 PM |
Re: 3D blank on 1 project while working on other projects If your project is on only one level, try to select all items in the plan and paste them in a new home. I'm not sure it will work but it's something you can try by yourself. Otherwise, please send it to me, I'll investigate the problem on my side. ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
Current timezone is GMT Sep 28, 2026, 5:10:09 AM |
