Print at Sep 19, 2026, 9:27:28 PM
Posted by Arnoud at Aug 26, 2014, 11:19:41 PM
Is there a maximun file size for sh3d files?
Lately I've added a lot of new objects by grouping and texturing boxes and cylinders into custom objects. The sh3d has grown to 67.794 kB. Now I can't render pictures anymore, the rendering just freezes in the inital phase.
Posted by hansmex at Aug 27, 2014, 2:30:30 AM
Re: Is there a maximun file size for sh3d files?
Try these:
- read the FAQ and do the XMX trick
- delete half of your models, then try to make a render; if it works, probably one of the deleted models is faulty. If not, restore your deleted models, delete the other half, and repeat the procedure.
Posted by Arnoud at Aug 28, 2014, 2:19:20 AM
The XMX trick did the trick partially. I can now render a picture but can't save it. Th program freezes at that poit, will try deleting models tomorow.
Posted by Puybaret at Aug 28, 2014, 2:22:45 AM
Do you use a 32 or 64 bit system?
Posted by Arnoud at Aug 28, 2014, 8:43:42 PM
I have Windows 7 64 bit. Until this week I din't have this problem...
Posted by Puybaret at Aug 28, 2014, 9:20:27 PM
Why happens when you try to save the image?
Posted by Arnoud at Aug 30, 2014, 1:57:25 AM
That's just what bothers me, why a freeze when I only want to save the rendered picture?
