Sweet Home 3D Forum » List all forums » » Forum: Gallery » » » Thread: Starship Enterprise 2nd Walk-Thru |
| Print at Aug 22, 2026, 2:43:05 PM | |
| Posted by Desslok at Aug 12, 2014, 9:48:48 AM |
Starship Enterprise 2nd Walk-Thru And here is another slightly longer walk-thru featuring the transporter room, sickbay, the O.R. Doctor McCoy's office and the lab. Most of this is still very rough. I work a little at a time jumping around from one part of the ship to another. I'm starting to wonder if and when I'll run up against the limit of what the program can do. Link to video [Note from moderator: updated link to video] |
| Posted by sree.arun.kr at Aug 12, 2014, 12:08:10 PM |
Re: Starship Enterprise 2nd Walk-Thru Wah!. Both videos are Super.Smooth camera path and custom texturing in walls that I like in this video. ![]() ---------------------------------------- ![]() |
| Posted by Desslok at Aug 12, 2014, 7:53:05 PM |
Re: Starship Enterprise 2nd Walk-Thru Thank you. It's a lot of work. I have 3 computers, but I have trouble getting Sweethome3d to run on two of them. One refuses to run it altogether (Dell Dimension 8400 running XP) another runs it but some of the features won't work (Dell GX270 also running Xp) The 3rd computer is my laptop running Vista and it runs it fine, but renders Sloowwwllly. |
| Posted by sree.arun.kr at Aug 12, 2014, 8:37:30 PM |
Re: Starship Enterprise 2nd Walk-Thru If you like then do a small tweak to speed up rendering. Go to SH3D installation folder : "C:\Program Files\Sweet Home 3D " create a new file : "SweetHome3D.l4j.ini " Add following lines : -Xms320m -Xmx768m -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.lowQuality.antiAliasing.min=0 -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.lowQuality.antiAliasing.max=0 -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.antiAliasing.min=0 -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.antiAliasing.max=1 Save the file and Re-render to see the result. * .ini is the extension format of the file. -Xmx768m : is the Maximum Memory to be used that depends upon your computer RAM. -Dcom.eteks.sweethome3d.j3d.PhotoRenderer.highQuality.antiAliasing.max=1 : is the antialiasing to be used in high quality. Default for minimum 1 and maximum 2 in high quality rendering. Higher value slow down the rendering time but gives quality. ---------------------------------------- ![]() |
| Posted by ccmehil at Aug 20, 2014, 6:57:15 PM |
Re: Starship Enterprise 2nd Walk-Thru Any chance to share it again or am I missing where the link is? I saw your other posts amazing work! |
| Posted by Puybaret at Aug 20, 2014, 8:53:11 PM |
Re: Starship Enterprise 2nd Walk-Thru I just updated the link in the first message. Enjoy ![]() ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by Desslok at Aug 27, 2014, 7:16:00 AM |
Re: Starship Enterprise 2nd Walk-Thru Thank you. I have also posted the videos on YouTube. And I have a new image recently rendered of the transporter room on my facebook page. Kenneth Mayes. I will post it here as well as soon as my internet connection improves. It's sllllooooowoowwww right now. |
Current timezone is GMT Aug 22, 2026, 2:43:05 PM |
