Print at Sep 19, 2026, 6:42:37 PM
Posted by Lumaja at Jul 30, 2014, 5:35:54 PM
Making continues walls
Making continues walls.
Wall thickness .10
No.1 – Enter 2.040 and is correct 1.940
No.2 – Enter .800 is correct at .700
No.3 – Enter .410 is wrong should be .310
No.4 – Enter 1.630 is wrong should be 1.530 ( after enter No.3 the wall turns up I have to turn down or
enter angle 0 degrees).
No.5 – Enter .845 is wrong should be .745
No.6 – Enter .700 is wrong should be .610
what am i doing wrong?
Posted by hansmex at Jul 30, 2014, 5:53:28 PM
Re: Making continues walls
It's difficult to help you without your sh3d file.
Look here to see how you can share it.
Posted by Lumaja at Jul 31, 2014, 9:34:03 AM
More Help
How to get picture of the plan 2D I only get 3D picture
Posted by okh at Jul 31, 2014, 11:54:54 AM
Depends what you mean. Adjust window you want to correct size.
  • Taking a screenshot (picture of screen/window):
    PrtSc or Alt+PrtSc copies screen/window to clipboard in Win and many Linux environments
    Cmd+Shift+Ctrl+3 or Cmd+Shift+Ctrl+4 in OS X (I think).
    (You need to save the clipboard to a file. Annoyingly procedures for this have changed in newer Windows versions, but pasting the clipboard to some graphics software and saving always works.)
  • AND/OR Save and Compress (Ctrl+Alt+S) your SH3D plan.
  • Upload files according to Hansmex' link above.
Posted by Lumaja at Jul 31, 2014, 3:50:04 PM
Thank you for you help
My idea was to send to you a picture of my 2D plan as your ask before, taking the print screen is a
picture of all the screen include SH, is this the way you want?
Posted by okh at Jul 31, 2014, 4:05:59 PM
Hi again, I have still not quite understood your problem in the first post, therefore maybe the plan and/or a screenshot could help explain as Hansmex suggests. ok
Posted by Lumaja at Aug 1, 2014, 9:39:21 AM
Thank you all your people for the help.
I still don’t understand how to share a picture or share a file, my picture is in Ubuntu Home folder with name TRY 66 I tried but it dint come like your explained.
I don’t want annoying your people with this and I carry on making one wall at a time.
Once again Thank you.
Posted by dorin at Aug 1, 2014, 2:06:18 PM
About your problem with drawing walls, read again this:
http://www.sweethome3d.com/userGuide.jsp#drawingWalls
For the connected walls install AdvanceEditing plugin.
For share or insert a picture follow this:
http://www.sweethome3d.com/support/forum/viewthread_thread,1886
You can't upload something directly from your computer but via mediafire.
Dorin
Posted by Lumaja at Aug 14, 2014, 8:27:24 AM
Hoping this is correct.
http://file:///home/luis/TRY66.png
Posted by dorin at Aug 16, 2014, 7:17:55 PM
NO, is not correct!
You CAN'T use your local file.
You must create an account on madiafire.com (for egsample), upload your files ther and then share it according to this tutorial.
Dorin
PS
The tutorial is a little bit outdated but after few attempt you will win.
Good luck!
Posted by Lumaja at Aug 21, 2014, 8:26:35 AM
http://www.mediafire.com/view/k7hh2e808xv81hv/TRY66.png
Thank you for the grate help I think I achieved something
As you wrote is outdated.
Insert my picture hope this time is correct.
Posted by dorin at Aug 21, 2014, 3:10:34 PM
Finally is relatively correct.
Now I understand Your problem related in initial post.
The program compute correct the dimensions wile consider the visible side of wall. The walls from 3~6 have an extra .10 thickness from walls you have draw before and after. It's very close to real world when you try to measure some walls.
To make continuous walls you need:
1. Install this great plugin;
2. Start drawing walls in one step (no mater the precise but the general aspect). That's mean you point and click (ONE CLICK) for every end of the wall.
3. The end of the last wall is preferably to be over the start point of the first wall. Finish drawing by double click, then press ESC.
4. In menu bar click on selection icon (the arrow).
5. Select LAST wall, press Shift + select FIRST wall to have both selected.
6. Wile selection go to Plan -> Connect walls .This option appear ONLY if the AdvacedEditing plugin is installed.
After few attempts I'm sure You got'it.
Posted by okh at Aug 21, 2014, 3:15:34 PM
Guessing from your picture and list of "errors", it could be that you are not aware that walls are measured from the centre point. This means you have to add or subtract half the wall thickness for each turn if you want to enter dimensions in the wall properties.
However, as it appears you are working with indoor measurements, there may be an easier way of doing this:
- Open an empty plan,
- draw a ROOM (not wall, use the Room-tool) with the dimensions you want,
- (if you need to, zoom in on each corner and use the SELECT tool to move the corner exactly where you want it),
- set the correct wall thickness in PREFERENCES
- now, use the WALL tool and double-click on the room,
The wall should now fit snugly around the room, and your (indoor) measurements (and walls) should be correct.
Or did I misunderstand your problem?
Posted by Lumaja at Sep 3, 2014, 11:48:09 AM
To Dorin
Thank you for the advise,
Downloaded plugin as your suggested, on Readme.txt there is explanation to install under Linux and other Unix, it's the subfolder .eteks/sweethome3d/plugins of your user folder, I cant find the subfolder eteks in plugins.
My SH is .tgz file don’t know if there is a difference, please advise.
To Okh
Thank you for your advise, it works.
Posted by dorin at Sep 8, 2014, 1:40:18 PM
cool   Re: Making continues walls
1. Read at the end of this
2. Download AdvancedEditing.sh3p file from here
3. In your home directory (under linux) IF you have run at least once the SweetHome3D program you will find a hidden directory .eteks.
In this one you will have the directory sweethome3d .
There if you don't have allready a directory name "plugins" you must create it.
4. In this directory you have to copy the AdvancedEditing.sh3p file.
5. Restart the SweetHome3D program.
P.S. My SH3D is also .tgz smile
PPS My path is /home/dorin/.eteks/sweethome3d/plugins/
Posted by Lumaja at Sep 16, 2014, 10:00:40 AM
Again thank you for all the help.
I am sorry to be a pain but this gremlin of .eteks continues.
Search my Home folder and SW folders but no result, checked for hidden files the same.
Follows a screenshot of SW folder, there is a Plugin with Desktop and i386 subfolders but no .eteks.
I downloaded AdvancedEditing plugin.
Posted by Puybaret at Sep 16, 2014, 10:41:00 AM
Here's an other way that you might find easier:
- Open a Terminal window
- Drag and drop the icon of SweetHome3D program on Terminal window to copy its path
- Type a space in the Terminal window
- Drag and drop the icon of the .sh3p plug-in file on Terminal window to copy its path
- Press <enter> in the Terminal window
This should run a command like:
/folder/SweetHome3D /anotherFolder/AdvancedEditing.sh3p
that will install the plug-in at the right place.
[Edit: don't use the -open parameter]
Posted by Lumaja at Sep 18, 2014, 6:24:09 PM
To Dorin
Found .eteks in root/home, made a mistake and extract direct into eteks which is wrong, now need help
to delete the extract don’t know to do this.
There inst “plugin” folder in eteks/sweethome3d must I create this folder while extracting?
Posted by dorin at Sep 23, 2014, 4:11:51 PM
First Let's make clean on your mess.
1. As normal user (use your favorite file manager):
--Go to folder where you download and extract the SH3D program. Delete
the extracted folder.
--Keep the SweetHome3D-4.4-linux-x64.tgz or SweetHome3D-4.4-linux-x32.tgz. and the AdvancedEditing.sh3p file.
--Open an terminal (console):
--type su
--type your root password
--type mv /root/home/.eteks
--type exit & close the terminal.
2. Right click on SweetHome3D-4.4-linux-x64.tgz and select "Extract here"
3. Open the new extracted folder (SweetHome3D-4.4) and double click on SweetHome3D file. In few seconds SH3D is runing. Close it.
4. NOW you must already have create something like this:
/home/dorin/.eteks/sweethome3d/ (in my case)
/home/lumaja/.eteks/sweethome3d/ (probably in your case)
---You wheel find 3 folders (furniture; langueges; textures) and a file (preferences.xml)
5. Create here an new folder name plugins
6. Copy in this folder the AdvancedEditing.sh3p file
7. Go to SweetHome3D-4.4 folder and double click on SweetHome3D file.
Posted by Lumaja at Sep 24, 2014, 1:23:09 PM
My system don’t accept my password with “su”.
luis@luis-G41M-Combo:~$ su
Password:
su: Authentication failure
is there another command to replace “su”
Posted by Puybaret at Sep 24, 2014, 3:43:17 PM
Lumaja, did you try the solution I posted?
Posted by dorin at Sep 25, 2014, 8:49:57 AM
1. This forum is not intend to be for how to administrate various kind of linux systems. The "su" command is the classic way to become "root".
I suppose You have some kind of *buntu or *mint. You could tell me more by typing in terminal: infobash -v3
2. Anyway you could skip the part with "su" and continue with steep 2
Posted by Lumaja at Sep 25, 2014, 4:48:36 PM
Yes, and just did it again the file in .eteks Plugins are all there, made two walls in SH looking
into Plan Connect walls is not there.
Posted by Lumaja at Sep 25, 2014, 4:59:29 PM
I have all the extracted files of AdvancedEditing in eteks/Plugins
Thank you.
Posted by dorin at Sep 26, 2014, 9:54:11 AM
1. In a previous post I've made a mistake:
--type su
Please replace mv /root/home/.eteks with rm -rf /root/home/.eteks/
2. As normal user (luis) open a terminal and type:
2.1. ls -al /home/luis/.eteks/sweethome3d/
You should have something like these:
drwxr-xr-x 8 luis luis 4096 Aug 29 13:39 .
drwxr-xr-x 3 luis luis 4096 Aug 9 2012 ..
drwxr-xr-x 2 luis luis 4096 Sep 1 08:19 furniture
drwxr-xr-x 2 luis luis 4096 Mar 31 10:39 languages
drwxr-xr-x 2 luis luis 4096 Aug 14 10:25 plugins
-rw-r--r-- 1 luis luis 16440 Aug 29 13:29 preferences.xml
drwxr-xr-x 2 luis luis 4096 Aug 29 13:31 recovery
drwxr-xr-x 2 luis luis 4096 Feb 25 2014 textures
drwxr-xr-x 2 luis luis 4096 Sep 1 08:21 work
2.2. ls -al /home/luis/.eteks/sweethome3d/plugins/
In my system I have this:
drwxr-xr-x 2 dorin dorin 4096 Aug 14 10:25 .
drwxr-xr-x 8 dorin dorin 4096 Aug 29 13:39 ..
-rw-r--r-- 1 dorin dorin 103612 Aug 7 20:46 AdvancedEditing.sh3p
-rw-r--r-- 1 dorin dorin 3849 Apr 16 19:07 calculateWalls.sh3p
-rw-r--r-- 1 dorin dorin 15632 Oct 3 2010 CopyStylePlugin.sh3p
-rw-r--r-- 1 dorin dorin 7974 Sep 7 2013 DimensionLines.jar
-rw-r--r-- 1 dorin dorin 29365 Jun 15 2009 ExportToSH3F-1.0.sh3p
-rw-r--r-- 1 dorin dorin 14949 May 24 2009 RotateHomePlugin.sh3p
-rw-r--r-- 1 dorin dorin 54536 Dec 24 2013 UtilityPlugin.sh3p
-rwxr-xr-x 1 dorin dorin 2840 Jun 8 2009 VolumePlugin.jar
That's the way my SH3D work great.
Hope this is helpful for You.
Posted by Lumaja at Sep 26, 2014, 3:29:37 PM
Tried ls -al /home/luis/.eteks/sweethome3d/plugins/
luis@luis-G41M-Combo:~$ ls -al /home/luis/.eteks/sweethome3d/plugins/
total 44
drwxrwxr-x 4 luis luis 4096 Sep 26 14:07 .
drwxrwxr-x 9 luis luis 4096 Sep 26 14:20 ..
-rw-rw-r-- 1 luis luis 18347 Oct 4 2006 COPYING.TXT
drwx------ 3 luis luis 4096 Sep 26 14:07 de
-rw-rw-r-- 1 luis luis 758 Jul 16 22:12 LICENSE.TXT
drwx------ 2 luis luis 4096 Sep 26 14:07 META-INF
-rw-rw-r-- 1 luis luis 789 Jul 16 22:10 README.TXT
is totally different why is this ?
Posted by dorin at Sep 30, 2014, 9:04:19 AM
You have extract the AdvancedEditingPlugin-src.zip file.
You need only the AdvancedEditing.sh3p file to be copy in plugins directory.
Solution:
1. Go in /home/luis/.eteks/sweethome3d/plugins/ and delete all.
2. Download AdvancedEditing.sh3p file and copy in plugin directory.
3. Start SH3D program.
P.S. That's how to install plugins in SH3D.
Posted by Lumaja at Sep 30, 2014, 2:50:05 PM
Thank you, eventually is in SH and can connect walls.
Went to see with ls -al /home/luis/.eteks/sweethome3d/plugins/
total 112
drwxrwxr-x 2 luis luis 4096 Sep 30 13:25 .
-rw-rw-r-- 1 luis luis 103612 Sep 18 09:45 AdvancedEditing.sh3p
Not the same as you get, is the difference matters?.
Posted by dorin at Oct 2, 2014, 12:47:23 PM
NO!
I have installed more plugins then You have.
Now, in menu bar of SH3D, You must find:
Menu bar Plan -> Connect walls.
To use this You must have some walls draw in plan.
Remember ALL walls have a start point and an end point.
You can connect the end point of FIRST selected wall with the start point of the SECOND selected wall.(use Shift for this).
Make some tests on a mew plan to learn how it's work.
Their is more tricks to discover like 2 clicks.
