Sweet Home 3D Forum » List all forums » » Forum: 3D problems » » » Thread: No rendering, only black window |
| Print at Sep 19, 2026, 6:56:02 PM | |
| Posted by enzoleva at Jul 18, 2014, 4:41:13 PM |
No rendering, only black window Help me, please! Suddenly the rendering of the program doesn't work, I believe after having installed Xampp, also when this program is not on. I have also tried to re-install Java, DirectX and the same program, but nothing doesn't change. Practically, to the rendering is overlapped a black screen, and if you can sometimes see something, they are only gray and white blocks. What can I do? Thank you anticipate to whom helps me to recover this program. |
| Posted by hansmex at Jul 19, 2014, 11:32:07 AM |
Re: No rendering, only black window Maybe you can send me your file? Hans ---------------------------------------- Hans Ryzen 7-9700X, 32 GB RAM, 500 GB SSD, 2x 2 TB SSD, Geforce GTX 1060 3 GB |
| Posted by mataha at Aug 25, 2014, 3:11:04 PM |
Re: No rendering, only black window yes my problem like as enzoleva. blackscreen in 3D view. i just update 3D rendering, java etc, but nothing change. |
| Posted by Puybaret at Aug 25, 2014, 6:15:44 PM |
Re: No rendering, only black window What size and quality did you try? ---------------------------------------- Emmanuel Puybaret, Sweet Home 3D creator |
| Posted by mataha at Aug 26, 2014, 5:47:08 PM |
Re: No rendering, only black window this my spec computer intel pentium 4 CPU 1.8GHz Memory 512Mbytes Graphic NVIDIA GeForce FX 5500 256MBytes. Setting grapics screen resolution 1440 by 900 pixels. |
| Posted by mataha at Aug 29, 2014, 2:35:04 PM |
Re: No rendering, only black window i found how to 3D view. you must update latest version of VGA driver. i`m use nvidia gefoce FX 5500 (too old VGA hahah) but update VGA driver is best solution. soo no more black window at 3D view |
Current timezone is GMT Sep 19, 2026, 6:56:02 PM |
